hand brake light under heavy braking??
After a spirited driver i noticed my hand brake light was coming on under heavy braking. This only happened once my brakes had got red hot and had faded quite badly. I know my front pads are due for a change and the fluid is pretty worn out too but does the light double up as a warning light or have i just got a loose sensor on the hand brake lever?
Only came on when slowing from 60 (ish) down to 2nd gear corners with full brake applied.
It's an indication to check your brakes in general. First port of call would be to check your fluid reservoir. It might be a bit on the low side and need topping up
Fluid level is ok but the disks are on their way out and the pads are very very low. Fluid is probobly ruined too as the brakes faded very very quickly. Its fine on normal driving and i have complete replacments coming so i'll ignore it for now. Thanks chaps.
