Eibach Springs
JordanHill
Has anyone had these or some other lowering springs fitted but kept the standard camber arms? just want to see what it looks like on stock set up.. I know there will be more camber but just wanted to see by how much?
Also pros and cons to doing/not doing the arms would be great!
Cheers
You won't really notice a different look, but you will notice the eaten tyres. It's important that you get adjustable rear camber arms if you are fitting Eibachs or similar drop springs to bring it back into stock camber.
You can get away without them if you fit Tein springs as they don't drop as much.
Edited by Jp606
When I fit my elbach springs I could see the camber was out and it would need sorting so I fit the camber adjusters and the toe bolts was 6 hours work to do the first time iv ever done them easy really. Iv not done any thing to the front and it's all set up at about 1.5 camber and minimum toe :-)
Sent from my iPad using Tapatalk
