Help a fellow zed stuck in deciding...
sam350z2013
Hi,
Wanted to ask other Zed owner's opinions. I found oil on the spark plugs whilst changing them recently.
I read around that the rocker covers and gaskets may need changing. But I'm currently on bit of a budget and won't be able to change these yet. So wondering if I continue to drive the Zed and top up the oil levels regularly. Will this do any damage to the engine ?
Any input will be greatly appreciated!
Thanks.
I would get some thin rag and very carefully push it down around the plug to soak up the oil. ( use a thin long screwdriver ) Take your time and dont be aggressive and break the plug.
You can then inspect a week later and see how bad its leaking. This will help you decide how important it is to get the job done or if you can wait a while.
One things for sure it will only get worse and not better but but the leak may not be as bad as you imagine.
Edited by gsexr
If your handy with the spanners then it's not a hard thing to change.
The problem is when the seals around the plugs go you can't just change the gasket you have to change the cover (plug seals are pressed in)
Be sitting down when you get the price for a new cover :scare:
You can change the rocker covers/gaskets yourself if you feel up to the task. I've never done it myself but shouldn't be too difficult as Alex mentions in the quote below.
Zmanalex said: "Very easy to fit mate and take less than 1 hour per side as a DIY
You will also have to replace the gaskets."
First you will need the below items;
http://www.350z-uk.com/topic/80779-rocker-cover-gaskets-for-oil-leaks-vq35de/page__hl__rocker
http://www.350z-uk.com/topic/80780-new-nissan-cam-cover-assembly-vq35de/page__hl__rocker
The link below should help you out but if you still need help I'd try a PM to Zmanalex as he's a fountain of knowledge. ;)
Page 41 onwards should help; http://www.nicoclub.com/FSM/350Z/coupe/2004.5/em.pdf
Hope that helps some. :thumbs:
