Fluke Posted February 26, 2014 Share Posted February 26, 2014 (edited) I am planning on putting together a new ICE system to replace my Bose amp, speakers, Appradio 2 and tablet install. I have already purchased a Pioneer AVIC - 8500bt, I have a different tablet already built up in a custom made flocked cubby. I just need to decide on the speakers, sub and amp, I was thinking of the following: Hertz ESK 165 2 way 16.5cm components for the front. £139.00 Hertz ECX 165.5 16.5cm coaxial 210 watt 2 way door speakers for the rear. £89.00 Alpine MRX -v70 5 channel amp. £250.00 Can anyone see a problem with what I have chosen or recommend anything better for the price? Edited February 26, 2014 by Fluke Quote Link to comment Share on other sites More sharing options...
Briggsybriggs1 Posted February 27, 2014 Share Posted February 27, 2014 Sub ???? The speakers iv never used before I would use infinity ref or kappa my self but iv never used anything different . Well apart from the sub Iv got now :-) Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
un1eash Posted February 27, 2014 Share Posted February 27, 2014 Speakers are a personnel preference, I've used infinity kappa in my MR2 before but only use JL now. I don't think you can go wrong with the Hertz, the quality will be more down to the install and amp running them. 1 Quote Link to comment Share on other sites More sharing options...
Fluke Posted February 27, 2014 Author Share Posted February 27, 2014 Can anyone recommend a sub that will fit I the OEM location. Quote Link to comment Share on other sites More sharing options...
Grundy Posted February 27, 2014 Share Posted February 27, 2014 I've only ever had one sub (apart from stock bose) and that was a 3000watt 12" Pioneer, and the sound was amazing (dependent on what amp you get) I'd highly recommend Pioneer, I know the stock is 10" and I can't see and issue with a straight swap. Someone on here did a DIY for installing a 12". Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted February 27, 2014 Share Posted February 27, 2014 I usually use genesis amps and focal speakers Quote Link to comment Share on other sites More sharing options...
Briggsybriggs1 Posted February 27, 2014 Share Posted February 27, 2014 On 27/02/2014 at 13:29, Fluke said: Can anyone recommend a sub that will fit I the OEM location.most 10 inc subs will fit in I fit a clarion in The stock place just needed different screw holes drilling :-) Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
OV53 Posted February 27, 2014 Share Posted February 27, 2014 Hertz are an excellent choice, I've dealt alot with them in the past and you can't fault the quality. As for your amp.....if I could make a suggestion, I have only ever had one Alpine amp and I popped it in less than 6 months, very weak to be fair. Have you thought about maybe binning the coaxials? There is no need for them if you have components, seriously. By doing that you can put that money towards a better amp (Rainbow iPaul 4.300 - best amp I've ever had for the money) and then get a reasonable sub bridged over 2 of the channels. I won SQ competitions with just components and a sub using this amp coupled with a Pioneer headunit. Coaxials will add depth but no extra quality. Apologies for the mad way that this is put together, my battery is about to die! Quote Link to comment Share on other sites More sharing options...
samu23 Posted February 27, 2014 Share Posted February 27, 2014 (edited) Which tablet is in the pic and which one are you changing to? I have always sworn by JL Audio, you'd need a free-air sub for the stock location as it is not air tight. Most people tend to move a sub to the boot/under the strut brace. Edited February 27, 2014 by samu23 Quote Link to comment Share on other sites More sharing options...
Fluke Posted February 27, 2014 Author Share Posted February 27, 2014 The tablet is 16gb Nook Hd with 32gb micro Sd and I have built another one using an Apple Ipad mini, because all my purchases are on the Apple store and I was recently given the mini with a broken back panel. Quote Link to comment Share on other sites More sharing options...
Fluke Posted March 2, 2014 Author Share Posted March 2, 2014 Thanks to Phil (OV53), my plans have changed/gotten more expensive. I now have the following on the way: Pioneer AVH-8500BT head unit. Morel Tempo 6 - 2 way component speakers for the front. Hertz ES250.3 - 10" subwoofer. I still haven't decided on the Amp yet although Phil has suggested the Rainbow iPaul 4.300 (4 channel), but it looks like it may be to big for the behind the seat glove box, unless it will fit under the seat. Is it possible to run the rear speakers from the head unit for infill? Another option would be to get a set of Hertz Energy ECX165 6.5 coaxial speakers for the rear and an Alpine PDX-V9 5 channel Amp. The Amp will fit in the glove box and will give a cleaner install. Any opinions are welcome. Quote Link to comment Share on other sites More sharing options...
