Scott TMN Posted February 25, 2014 Share Posted February 25, 2014 Hi guys, booked in for a wheel alignment tomorrow on their Hunter system. Just wondering what kind of set up i should be aiming for, such as degree of camber etc? I have a 30mm drop with eibachs, camber adjustment arms, running 19" 10.5 and 9.5j wheels (not sure if wheel size makes a difference?). I would like to preserve tyre wear but at the same time I want the handling to be there if ever so need be... Thanks in advance Quote Link to comment Share on other sites More sharing options...
GT4 Zed Posted February 25, 2014 Share Posted February 25, 2014 (edited) There's no free lunch mate. Eg A good setup for handling twisties will increase tyre wear. Stick with the factory setup and you would have the best compromise. Aim to be in the upper ranges of OEM ranges if you can Front: Toe 0deg.00min though bit of toe out will even be better. Eg 0.05 Camber would be more negative than max OEM( 1deg20min)= good. However you can't adjust this anyway unless you have an adjustable arm Caster would be positive than max OEM(8deg.55min) = good. You can adjust it anyway unless you got an adjustable arm. Rear: Toe in 0deg.06min Camber negative 2deg.05min Since you are lowered do you have adjustable droplinks? Often forgotten but very important as you could preload your anti toll bars and worsen the roll. Most people counter this with stiffer damping with even makes your handling worse. So check the ARBs have no preload. Hope it helps. Edited February 25, 2014 by GT4 Zed 2 Quote Link to comment Share on other sites More sharing options...
Scott TMN Posted February 25, 2014 Author Share Posted February 25, 2014 thanks a lot for the detailed response mate, i would agree the upper limits of oem spec would be the best for me. I do have adjustable camber arms but i must admit the droplinks are something no thought was given too.. thanks mate Quote Link to comment Share on other sites More sharing options...
Briggsybriggs1 Posted February 25, 2014 Share Posted February 25, 2014 Had my car done today with the same mods I just told them to get it as near to the OEM set up, was put on there hunter and loads off red warning came up lol will copy the print out when I walk to the car later on :-) Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted February 25, 2014 Share Posted February 25, 2014 Check this out if it helps. http://www.350z-uk.com/topic/81207-3d-wheel-alignement/ Quote Link to comment Share on other sites More sharing options...
Scott TMN Posted March 4, 2014 Author Share Posted March 4, 2014 thanks for the posts guys, took me a few attempts due to toe bolt issues but here is my final settings 1 Quote Link to comment Share on other sites More sharing options...
parello9 Posted March 18, 2014 Share Posted March 18, 2014 thanks for the posts guys, took me a few attempts due to toe bolt issues but here is my final settings scott did you install the eibach toe bolt ? Quote Link to comment Share on other sites More sharing options...
Scott TMN Posted March 18, 2014 Author Share Posted March 18, 2014 (edited) Yes mate, with some concentrated heat on the old nut I was able to get the new bolts in I had to get it in as i was running waaay too much inward toe! Edited March 18, 2014 by Scott_f91 Quote Link to comment Share on other sites More sharing options...
KyleR Posted March 18, 2014 Share Posted March 18, 2014 Are you happy with the half a degree difference in camber on the rear? Quote Link to comment Share on other sites More sharing options...
Scott TMN Posted March 18, 2014 Author Share Posted March 18, 2014 Are you happy with the half a degree difference in camber on the rear? There isnt half a degree difference. There are 60 'minutes' to a degree. So there is only 3 minutes between the left and right side Quote Link to comment Share on other sites More sharing options...
KyleR Posted March 18, 2014 Share Posted March 18, 2014 Are you happy with the half a degree difference in camber on the rear? There isnt half a degree difference. There are 60 'minutes' to a degree. So there is only 3 minutes between the left and right side Ah I see it now, my mistake, didn't pay enough attention to the "dot" 1 Quote Link to comment Share on other sites More sharing options...
parello9 Posted March 18, 2014 Share Posted March 18, 2014 Oh okay just my mechanic said they look a right pain to fit as you gota drill away Quote Link to comment Share on other sites More sharing options...
Briggsybriggs1 Posted March 18, 2014 Share Posted March 18, 2014 Oh okay just my mechanic said they look a right pain to fit as you gota drill away The toe bolts are easy to fit mate you just need a rotary file for a 90deg drill. I did it led under my car so if it is on a ramp it should be very eAsy :-) Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
parello9 Posted March 18, 2014 Share Posted March 18, 2014 Oh okay just my mechanic said they look a right pain to fit as you gota drill away The toe bolts are easy to fit mate you just need a rotary file for a 90deg drill. I did it led under my car so if it is on a ramp it should be very eAsy :-) Sent from my iPhone using Tapatalk oh really ima give him a shout 2moz then thanks 1 Quote Link to comment Share on other sites More sharing options...
