1/2 inch plenum spacer kit
chrisrowsell
Hi gmballistic, thanks for reply, did you find this made much difference to your zed. Did you have the remap done ad well, this kit is now £159 which is reasonable.
Just noticed as well if you contact Horsham Developments you can have a custom size plenum spacer made according to the advert link I supplied if you did want 1/2" specifically.
I had my plenum spacer fitted by them just before I had my UpRev done so don't have a before & after to compare bhp increase unfortunately although it is dyno proven to make gains and from what I've read it equals out the air distribution between all the cylinders. Standard the first two cylinders don't get as much air in.
Tarmac Sportz are great suppliers too though and I have nothing but good things to say about both Chris@Tarmac & Jez@Horsham tbh. :thumbs: Can't go wrong with using either of these traders. ;)
