parello9 Posted February 19, 2014 Share Posted February 19, 2014 Just thinking for when i get my car lowered... To have a wheel alignment doing do you need adjustable camber arms and drop links i see people buying? or toe bolts maybe? abit confused that's all Quote Link to comment Share on other sites More sharing options...
370Ad Posted February 19, 2014 Share Posted February 19, 2014 If your just on springs it will be fine, Might need camber arms if on coilovers. Quote Link to comment Share on other sites More sharing options...
parello9 Posted February 19, 2014 Author Share Posted February 19, 2014 If your just on springs it will be fine, Might need camber arms if on coilovers. Yeh, well it will be the Hsd dual tech coilovers on driftworks but when i decide to buy them Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 19, 2014 Share Posted February 19, 2014 (edited) If you drop 30mm or more then you will require geometry correction arms for the rear and probably for the front as well so that you can dial back to factory geometry tolerences. Alex. Edited February 19, 2014 by ZMANALEX Quote Link to comment Share on other sites More sharing options...
parello9 Posted February 19, 2014 Author Share Posted February 19, 2014 If you drop 30mm or more then you will require geometry correction arms for the rear and probably for the front as well so that you can dial back to factory geometry tolerences. Alex. right ok and how much is this stuff for future knowledge ? Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted February 19, 2014 Share Posted February 19, 2014 We dropped a Zed 30mm on coilovers today and it needed rear camber arms for alignment, parts can be seen here for the front and rear kit - http://cougarstore.co.uk/index.php?main_page=index&cPath=1_9 Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted February 19, 2014 Share Posted February 19, 2014 Have a look at this thread . http://www.350z-uk.com/topic/81207-3d-wheel-alignement/ Quote Link to comment Share on other sites More sharing options...
parello9 Posted February 19, 2014 Author Share Posted February 19, 2014 Im hoping to get it decked so more than 60mm i should think.. thinking il need the rear camber arms then Quote Link to comment Share on other sites More sharing options...
KyleR Posted February 19, 2014 Share Posted February 19, 2014 60mm So you're going for the US slammed look and have your dampers turned up to 36? Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted February 19, 2014 Share Posted February 19, 2014 As Alex says 30mm or lower will require camber correction arms to get close to factory settings it just depends what you want to achieve handling wise. We keep the Eibach front and rear camber arms in stock as well as the Eibach rear camber and toe adjustment bolts. Drop me a PM if you need any advice Quote Link to comment Share on other sites More sharing options...
Briggsybriggs1 Posted February 19, 2014 Share Posted February 19, 2014 Just remember not meany garages can fit the equipment on to do the alignment on a lowered car as I have found out Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
