Pioneer AVH-X3600DAB help
Hudson
I have fitted the above unit in my 350Z but the volume is about half as loud as the standard bose stereo.
I have read up on here about it and seen the mod of cutting the rca ends off and joining to the speaker cables but wondered if there was an easier solution? If not is there a guide showing which colour speaker wires are for which side and front and back joined to the rca leads?
Thanks in advance
Sent from my GT-I9505 using Tapatalk
Edited by Hudson
Aerial was from here
http://www.dabonwheels.co.uk/Kinetic_DBA-5001_DAB_car_aerial.html
Fitting was much easier than I expected.
You need to remove the internal plastic trim from the boot to get to the back of the FM aerial and then it simply u screws.
Fitted the new one and ran wire to headunit.
Full signal straight away and never had any burble since.
One thing to note. If you have the factory satnav, you'll lose TMC as it uses the FM aerial. I didn't realise this when fitting and took me a while to realise. No great loss though.
