Dicky Posted February 18, 2014 Share Posted February 18, 2014 Went on hol for 2wks leaving the alarm system on. Came back to a flat battery. As it happens I totally forgot about disconnecting the negative before I left. I know the battery drain when standing with the alarm on is approx 0.7A which means on a new batt (which is a 52A/Hr) it would only last for about 3days. But it's got me wondering how should you prepare the Z when going on hol. Anyone looked into this? Quote Link to comment Share on other sites More sharing options...
Almeida1234 Posted February 18, 2014 Share Posted February 18, 2014 (edited) Garage is and disconnect the battery that's my choice. But if you don't have a garage that's out of the window. On my RX-7 I have a treacle charger about 10-15 pounds from maplins. It keeps the battery at constant voltage instead of draining via alarm etc. However good battery should not have any issues even with alarm for couple of weeks. Edited February 18, 2014 by Almeida1234 1 Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted February 18, 2014 Share Posted February 18, 2014 Whenever i go away, i leave my car in the garage with the trickle charger attached, that way its fully charged when i'm back! Quote Link to comment Share on other sites More sharing options...
firemansim Posted February 18, 2014 Share Posted February 18, 2014 Garage is and disconnect the battery that's my choice. But if you don't have a garage that's out of the window. On my RX-7 I have a treacle charger about 10-15 pounds from maplins. It keeps the battery at constant voltage instead of draining via alarm etc. However good battery should not have any issues even with alarm for couple of weeks. Is your battery charger sticky? 2 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted February 18, 2014 Share Posted February 18, 2014 Garage is and disconnect the battery that's my choice. But if you don't have a garage that's out of the window. On my RX-7 I have a treacle charger about 10-15 pounds from maplins. It keeps the battery at constant voltage instead of draining via alarm etc. However good battery should not have any issues even with alarm for couple of weeks. Is your battery charger sticky? Is this the charger you got from Maplins Almeida? ;) Seriously though a trickle charger is the way to go as Almeida meant ~ my mate has one for his Subaru which is rarely driven & it starts first time, every time. Quote Link to comment Share on other sites More sharing options...
Flex Posted February 18, 2014 Share Posted February 18, 2014 Mmmmm treacle Quote Link to comment Share on other sites More sharing options...
ianboom Posted February 18, 2014 Share Posted February 18, 2014 That's a big drain for an alarm?? Quote Link to comment Share on other sites More sharing options...
glrnet Posted February 18, 2014 Share Posted February 18, 2014 I think you meant this GMB 1 Quote Link to comment Share on other sites More sharing options...
350 Russ Posted February 18, 2014 Share Posted February 18, 2014 I think you meant this GMB The oil out of my old Astra turbo used to look like that by the end Quote Link to comment Share on other sites More sharing options...
GMballistic Posted February 18, 2014 Share Posted February 18, 2014 I think you meant this GMB The oil out of my old Astra turbo used to look like that by the end Bet it didn't taste as good though. Quote Link to comment Share on other sites More sharing options...
Almeida1234 Posted February 18, 2014 Share Posted February 18, 2014 Mmm Treacle tart Ok I blame my ipad for auto correct lol Quote Link to comment Share on other sites More sharing options...
GMballistic Posted February 18, 2014 Share Posted February 18, 2014 Mmm Treacle tart Ok I blame my ipad for auto correct lol Quote Link to comment Share on other sites More sharing options...
Dicky Posted February 18, 2014 Author Share Posted February 18, 2014 Garage is and disconnect the battery that's my choice. But if you don't have a garage that's out of the window. On my RX-7 I have a treacle charger about 10-15 pounds from maplins. It keeps the battery at constant voltage instead of draining via alarm etc. However good battery should not have any issues even with alarm for couple of weeks. Take your point about the batt charger but not the couple of weeks. Mind you I would have thought the same thinking the current drain would have been a lot less than it is. As I said above its a 52A/hr batt so if the car's taking 0.7 A then it only lasts 52/0.7 ie 72hrs and then it's flat. The trickle charger sounds like a fix but Not sure how the insurance company would view it if it caught fire and burnt the house down? Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted February 19, 2014 Share Posted February 19, 2014 I've been leaving mine on my car for years. just don't get a cheapo one otherwise that would be the case! Quote Link to comment Share on other sites More sharing options...
The Bounty Bar Kid Posted February 28, 2014 Share Posted February 28, 2014 So a bit of a revive here, is it best advised to disconnect or not. Away for 10/11 days, and just installed a new car battery a few weeks ago. Bosch S005, courtesy of GT4 ZED. AH 77 CCA 780 Quote Link to comment Share on other sites More sharing options...
