Arran Posted February 14, 2014 Share Posted February 14, 2014 Evening all Couple days ago the airbag light came on flashing so I tried to reset the light via the key method but came straight back on after diagnostic mode, plugged it into snap on and it comes up with code b1049 drivers airbag module open. Just realised that I have no horn now Could it be the actual airbag or the clock spring behind it? Bearing in mind my steering angle sensor is ****ed aswell so my esp and skid lights are on but I know how that was caused so no issue there. I have the part already to fit aswell as a spare clock spring. Just wondering wether the clock spring is gone or the airbag What you reckon all? Cheers Quote Link to comment Share on other sites More sharing options...
R35LEE Posted February 15, 2014 Share Posted February 15, 2014 It's the clock spring Arran, seen it a few times Quote Link to comment Share on other sites More sharing options...
Arran Posted February 15, 2014 Author Share Posted February 15, 2014 Excellent thanks lee, just aswell ive got that complete unit spare with steering angle sensor. Is it hard to fit? Might give it a bash later when the weather sorts itself out I take it all the lights will turn off once fitted or do I need it plugged into nissan? Quote Link to comment Share on other sites More sharing options...
R35LEE Posted February 16, 2014 Share Posted February 16, 2014 When fitting make sure the clock spring cannot rotate using some tape that can earily be removed before fitting the steering wheel. Once fitted you have to have the srs light reset. Easy to do but make sure batter is disconnected prior to taking this on Quote Link to comment Share on other sites More sharing options...
PKAT Posted September 18, 2015 Share Posted September 18, 2015 How did you get on Arran? Quote Link to comment Share on other sites More sharing options...
