Jehuty Posted February 12, 2014 Posted February 12, 2014 Just driving my z and had a noise over a few frets of what can only be described as sheeting metal from front roght.. the sort of noise upto us expect with metal on metal brakes... Doesn't seem to be any visible damage and brakes seem fine. Stopped as quick as it started.. Any ideas? (Worrying about this car is driving me insane) Quote
RickyZ Posted February 12, 2014 Posted February 12, 2014 It could be your brakes, they have a pad wear indicator that when low makes a noise so you can avoid disk damage. You should be able to see if it's touching. Quote
glrnet Posted February 12, 2014 Posted February 12, 2014 Maybe a stone temporarily trapped between pad and disc Quote
GIXXERUK Posted February 12, 2014 Posted February 12, 2014 Maybe a stone temporarily trapped between pad and disc +1 it 's easy to check the pads with a torch (the inner always wears more though ) Quote
Keyser Posted February 12, 2014 Posted February 12, 2014 Could be the dust shield touching the disks? 1 Quote
