Key 'sticking' in ignition
WINKJ
Hi all,
as of recent the key is more difficult to take out of the ignition... almost as if its 'sticky'! any ideas how to sort it? or is it as easy as a bit of WD40..
no sexual references required! I have been around here for long enough to see how this very innocent question could quickly go down the wrong path! :lol:
You could put a tiny smudge of silicone grease on the key, but trouble is it will end up all over the inside of your pocket.
Also have you get a spare key? try that for a bit
+1.
I used WD40 on an old car before when I had the same problem and that worked. Sometimes it's just the tumbler inside clogged up with dirt & dust. :thumbs:
Went on a locksmith course and was told never to use wd40 on a lock as it lets fluff and debris stick to the lock wafers/pins!
We use graphite powder-good stuff but messy!
Maybe that's why mine had problems in the first place. :dry:
Doesn't matter now as sold the car decades ago but good to know I should use graphite powder next time should I ever get the same problem. ;)
