Headlight / washer problems
DiscoPotatoes
Hi
Recently noticed the headlight washer motor working but the washer wouldn't pop up?
Now the wife has told me the screen washer has stopped working!
I'm guessing its a fuse but if it isnt has anyone else had anything similar and found a fix?
Also how do you get to the reversing light bulb?
Cheers
Disco
Hi Disco ~ not sure on your screen wash problem but to get to the reversing light bulb there are two ways.
The hard way is to remove the rear bumper but the easier way is to remove your left rear light (pop off the three plastic bolt covers & remove the three 10mm bolts/then lift up the light unit) and you should be able to reach down to the bulb housing & twist it out. It is a bit awkward but much less hassle than removing the entire rear bumper just to change a bulb.
If you are still unsure have a read through this thread; http://www.350z-uk.com/topic/10841-how-to-install-silver-indicators-in-tail-lights/
It's for changing the rear indicators but it's the same for getting at the reverse bulb & fog light bulb. Hope that helps. :thumbs:
