Is there a 'simple' window reset?
14N
Hi All,
I've had the battery disconnected from my car for 2-3 weeks now for one reason or another :ninja: and I've reconnected it this evening. I've noticed that the window doesn't drop or raise that little bit when opening either door now. Is there a 'simple' reset procedure that I could/should try first, or is it door card off time to carry out the full reset by pressing that little button in the door?
There is ... I think it's wind down and hold for 3 seconds - wind up and hold for 3 seconds ... job jobbed
Cheers ATTAK. I thought there was but could only find the 'full' procedure when having a search. But now you've confirmed there is, I'll search a bit more.... :)
Found it, tried it, sorted it. :thumbs:
And for reference, here's what worked (with doors closed):
Pull switch up (fully close window)
Pull up & let go
Pull up & hold for 3 seconds
Push down and hold till window fully opens then let go
Push down & hold for 3 seconds
Pull up till window fully closed and let go
Pull up and hold for 3 seconds
Job done. This worked for both my driver and passenger windows.
Cheers guys :)
Edited by 14N
