Help with key code on focus.
Zhorno
IThere should be three copies of your keycode supplied with your Focus. One is onn a card about the same size as a credit card but just ordinary cardboard. It is on the bottom of a long thin strip of card containing key code instructions in various languages. The other two are sticky bits of printed instructions bearing your keycode which you should stick somewhere safe.If your mum is not the first owner have a look round various places inside the car where someone may have stuck the stickers.
If your car had alloys with locking wheel nuts you will need the keycode if you lose the special tool.
HTH
