Floydbax Posted February 6, 2014 Share Posted February 6, 2014 OK, so I tried all the usual off the shelf products and fixes I could find online but the green mould kept reappearing so I got a little more creative (thinking-wise) and hit on using this stuff : http://www.amazon.co.uk/Hibiscrub-250ml/dp/B001A33VRU/ref=sr_1_1?s=drugstore&ie=UTF8&qid=1391709441&sr=1-1&keywords=hibiscrub . It's an antibacterial cleanser that surgeons use for scrubbing-up and they're usually pretty clean folk . Using a soft nail brush I worked up a foam on the roof rinsed then repeated and finished off with the usual waterproofing stuff you paint on. That was over a month ago and we have had wonderful mould growing conditions all the time since but there's none on my roof. I will update in the future if it does reappear. 1 Quote Link to comment Share on other sites More sharing options...
HaydnH Posted February 7, 2014 Share Posted February 7, 2014 I like it! Definitely thinking outside the box! I have some of this stuff sitting in a cupboard from when I almost split my head in half (OK it wasn't that bad) and was advised to put it on the wound by the Spanish surgeons, but never used it as the NHS said to leave to wound alone. Great to know I now have a use for it if my soft top ever gets mouldy. Quote Link to comment Share on other sites More sharing options...
ragtopzed1 Posted February 7, 2014 Share Posted February 7, 2014 i used the Autoglym kit that comes with an agitator then a w/proof coating, seems to work well, be carefull of getting the waterproofer on paintwork, it leaves a greyish stain that only comes off with polishing. Quote Link to comment Share on other sites More sharing options...
Floydbax Posted February 7, 2014 Author Share Posted February 7, 2014 I like it! Definitely thinking outside the box! I have some of this stuff sitting in a cupboard from when I almost split my head in half (OK it wasn't that bad) and was advised to put it on the wound by the Spanish surgeons, but never used it as the NHS said to leave to wound alone. Great to know I now have a use for it if my soft top ever gets mouldy. OMG I'm pretty sure it says on the bottle not to use it on open wounds!!! Quote Link to comment Share on other sites More sharing options...
DrMatt Posted February 7, 2014 Share Posted February 7, 2014 Hibiscrub or more importantly its active ingredient chlorhexadine is a very good anti-microbial, but it is also very good at dissolving lots of things. I use it to clean bike grease, permananent ink, spraypaint etc and it will strip away lots of chemicals. Just make sure to reproof the roof like the OP or you might end up with a little spot that just lets water in! 1 Quote Link to comment Share on other sites More sharing options...
HaydnH Posted February 11, 2014 Share Posted February 11, 2014 I like it! Definitely thinking outside the box! I have some of this stuff sitting in a cupboard from when I almost split my head in half (OK it wasn't that bad) and was advised to put it on the wound by the Spanish surgeons, but never used it as the NHS said to leave to wound alone. Great to know I now have a use for it if my soft top ever gets mouldy. OMG I'm pretty sure it says on the bottle not to use it on open wounds!!! Well the injury was from a swimming pool in a dodgey hotel in Magaluf... they we're probably just being safe. Quote Link to comment Share on other sites More sharing options...
Floydbax Posted February 11, 2014 Author Share Posted February 11, 2014 After reading through some of the reviews on Amazon I guess it is a fairly mild cleanser, seems like a lot of people use it for cleaning their dogs and for skin conditions so the warning is probably just to cover the manufacturer and suppliers backs in the event of any adverse reaction to it. On the roof note - it's been 6 weeks now and where the mould used to return every few days I have to say IT'S STILL NOT COME BACK . Quote Link to comment Share on other sites More sharing options...
Floydbax Posted May 12, 2014 Author Share Posted May 12, 2014 Well guys, another 3 months and still no greenery, looks like it's a proper fix!!!! Quote Link to comment Share on other sites More sharing options...
Will370z Posted May 12, 2014 Share Posted May 12, 2014 Nice one, thanks for the feedback Quote Link to comment Share on other sites More sharing options...
Will370z Posted May 13, 2014 Share Posted May 13, 2014 Tempted to try this as i often park under trees now and get slight greeness on the roof. The autoglym isnt working as a long term fix so may give this a try. Just worried that it may mark the roof - different material on the 370 roof Quote Link to comment Share on other sites More sharing options...
Floydbax Posted May 13, 2014 Author Share Posted May 13, 2014 Wil370z, there's a difference between proper mould and just the green tinge from parking under trees. Mould is kind of growing inside the material and is really bad for it in the long run leading to rot, holes and leaks etc and unless you kill it (it's a micro-organism) it returns quite quickly. The green tinge from trees will usually just wash off with warm water and is like a surface thing that only occurs because of the stuff that drops onto it. I don't think the stuff I used would do any damage to your roof if you used it, it is after all quite a mild anti-bacterial soap and as long as you use a decent waterproofer afterwards then it should be OK. Quote Link to comment Share on other sites More sharing options...
Kev Posted May 25, 2014 Share Posted May 25, 2014 Vets use this stuff. My dog cut her paw. Ended up costing £650. It had to be dressed every other day and they used this to clean it between dressings. Quote Link to comment Share on other sites More sharing options...
Floydbax Posted August 12, 2014 Author Share Posted August 12, 2014 Quick update: It's now 6 months since I last resealed my lid and what one would call a great day for washing so I decided to do it today. There was still no sign of any mould at all. I have taken the plunge and used 303 protector this time and to be fair it looks like new after first 'Hibiscrubbing' it again. Yet to see how it compares with the scotchguard I used last time which worked perfectly. Quote Link to comment Share on other sites More sharing options...
