Wiring a sub to a non-bose, OEM head unit, Can it be done?
elrao
Hi guys
As i prepare my Z for sale, the to be owner has enquired about me leaving the sub in the car (Infinity Basslink) and wiring it into the standard Head Unit.
I currently have it wired up to my Alpine HU, using the Sub RCAs and the Alpine, remote switch (blue) wire to turn it on and off with the HU. I am pretty sure the standard Nissan unit doesn't have any RCA pre-outs, but are any of those wires a pre-out in disguise?
If not then I am assuming I would have to wire the sub in parallel to the rear speakers (Basslink has the option to connect via low level pre-outs or speaker level) and then find the correct "switch" wire on the back of the Nissan unit. So my questions:
Which wire is the remote turn on wire on the standard Nissan unit / wiring loom?
Are there any pre-outs hiding on the back of the standard unit?
If no pre-outs, is the best option to wire in parallel to the rear speakers?
Thanks
Rob
Hi guys
Thanks
Rob
The outputs from the BOSE unit are midway between RCA and speaker level as far as I know. That's why that adapter thingy is used when just changing the head unit.
In answer - 1. Don't know, not sure it matters because:-
2. No.
3. No, as I think the level still may be wrong for your Basslink.
