Passenger Window not dropping - PAIN!!
Kurtoski
This all of sudden stopped working as a passenger got out the car one day. I've tried the button in the door that activates the window drop and that does nothing? Any other quick solutions anybody can think of? I'm guessing it may be a problem with the sensor button as the windows operate as normal.
Any help would be much appreciated!
Sounds like the sensor - open the door you will see a black rubber covering a switch - push it in and out a few times see if that sorts it - it should earth the wire when the door is opened - only 1 screw holds it in so easy to take of and clean/inspect.
