Sound only from tweeters when playing radio?
Davectr
Can anyone help with this problem.
When listening to the radio on my 2010 roadster (Bose, sat nav) the sound is only coming from the front tweeters, yet when listening to any other source all the speakers work? I've been searching the web for an answer but cannot find the solution. I really don't understand how this can be, I've done the speaker test and searched through and tried adjusting all the different settings on the system to see if I can get it working correctly but to no avail.
Any suggestions great fully received.
Dave
  • 1 month later...
From the french Z forum:
Bon' date='je n'ai pas retrouvé le topic qui parlait du Bose/Clarion qui perdait son coté gauche,alors,si un modo peut deplacer ou replacer :wink:
Voila,en fouinant sur le fofo suisse, j'ai trouvé l'explication du mal qui ronge notre Bouse (Clarion):
> > thank you very much for your message.
> We can explain this problem. First we have to let you know, that the
radio/head unit is no BOSE product. We know, that Nissan has printed our
name on the front (to show everyone that this car has BOSE on board) but we
are not the manufacturer of this unit. It is from an other supplier, which
Nissan has selected.
> But apart from this, the problem sits not in the radio (for this reason it
does not use anything to replace the radio). The source of this problem is
the ribbon cable of the 6 CD-changer. This flexible ribbon cable brings the
music signals from the CD changer to the head unit. During driving this
cable rubs on an edge and after a while (the left) channel (or maybe others)
falls out temporary. For this reason we recommend you and your friends to
contact your local Nissan dealer and explain who the mistake sits. The
dealer should check this cable and repair/replace it. Than this phenomena
should disappear.
> Thank you for your understanding.
> Best regards
> Bose Automotive
> Customer Support Team Europe
> Klaus Hoehnle
http://www.350z-club...d=14&entries=45
Le pb ne viendrait donc pas de l'autoradio lui meme:ca ne sert donc a rien de le changer (Je crois que Liorem en est à son 10ieme,c'est ca? :shock: )...mais du cable qui relie l'autoradio et le changeur :wink:
Ca expliquerait pkoi le souci disparait lorsqu'on ecoute la radio par ex... :wink:
