32 point service
Randy_Baton
The only thing I have heard of similar to this is a 32 point inspection ~ not a service.
Do you have any history/bills/receipts with your car?
What year is it? mileage?
If you look at the service guide on here it will give you an idea of what should have been done to your car by now depending on age/miles. For example spark plugs should be changed at 54,000miles or every 5 years. ;)
+1 Certain items are mileage dependent
Edited by GIXXERUK
At the end of the day, all services are basically the same. They check all the wear items, change the oil and oil filter, change the air filter if it needs it and top up fluids if they need to be. All other major items are Mileage/age dependent as previously mentioned, and will only be changed if you tell them.
If you have no receipts for things being done, check the belts for wear, change if necessary, then change the spark plugs, brake/clutch fluid, gear and diff oil and coolant, then you'll know where you are and can breath comfortably knowing every things been done :thumbs:
Its 65k 2004 plate so a P3 was either due last year or in a few more miles. Getting a new clutch ASAP and will book it in for a P3 at the end of the summer. Belts are starting to squeal but should last the summer.
The garage that did the 32 point states they tailor it to the needs/age of the car but no receipts, I've emailed them to see if they have any further details.
