Ewen@Clark Motorsport Posted January 28, 2014 Share Posted January 28, 2014 (edited) Again common MOT failure and day to day wear and tear on the compression arms wears down these oil filled bushes causing play in the compression arms. The rubber perishes and the oil seeps out, if so its time to change the bush. Easily removed (with a press) we keep them on the shelf and can get them to you next day! They are £29.99 each Inc Vat Nissan UK will only supply the full arm @ over £295 and all is needed is the bush! So give get in touch if you are needing some! If you are needing the bushes PM us or you can buy direct from the site at the following link: http://www.clarkmoto...ush/54570-AC70A If your compression arm ball joints are worn then you will need new compression arms, we supply the genuine OEM Nissan arms for £250 per side, they can be found here http://www.350z-uk.com/topic/79145-genuine-nissan-compression-arms-350z-250-per-side/ Edited January 30, 2014 by Clark Motorsport/Zmanalex Quote Link to comment Share on other sites More sharing options...
