Ewen@Clark Motorsport Posted January 27, 2014 Share Posted January 27, 2014 (edited) Quite a common thing these days as rubber gaskets become aged they perish and then the rockers don't seal to the heads properly and the oil passes through leaking onto the engine and the manifolds. First place to check is the rocker cover gaskets and replace if needed. We keep both sides in stock if needed @ £12 each Inc VAT. http://www.clarkmoto...ductsSearch.asp Also if this doesn't fix your leak its possible you will need a plug tube gasket which is part of the rocker cover assembly. This is also something we stock, please view the link bellow: http://www.350z-uk.com/topic/80780-new-nissan-cam-cover-assembly-vq35de/ Edited January 27, 2014 by Clark Motorsport/Zmanalex Quote Link to comment Share on other sites More sharing options...
mick-r1 Posted January 28, 2014 Share Posted January 28, 2014 sweet... do you have the belts there too?? and i also need new plugs.... how much for the lot posted to ireland for me mate? Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted January 28, 2014 Author Share Posted January 28, 2014 PM on its way Quote Link to comment Share on other sites More sharing options...
