370z Akebono
Ceejay29
I am getting much closer to upgrading the poor JDM brake setup on the 350, ideally I would like a BBK but funds may not stretch this far. Tempted by the GT Brembo's although I fancy something different to the norm. I am currently leaning towards a 370z brake kit although I know very little about their brake setup...Do all 370's have Akebono brakes, or is this a further upgrade again? Has anybody fitted an Akebono brake kit to a 350?
Thanks
CJ
Hi Ceejay,
I have 2 complete sets of the Akebono callipers boxed, you just need a conversion bracket for the fronts which I am just ordering from the states this week :thumbs:
I have one of these sets from Lee.... waiting to fit now. Cannot recommend him enough, great help and super fast delivery!
  • Like 2
Looking good Gixxeruk. I have invested in some, Lee has been very helpful. Did you powdercoat/spray yours? I am tempted to do the same, do you know what extra cost I should factor in?
Hi, I sprayed them with hammerite smooth spray, very light thin coats to build the colour, allow each coat to dry and don't rush, I've used this on my last 3 cars, the last was a 911 I had for 4yrs and they still looked as good 3yrs after I sprayed them
It doesn't crack or fade
I can give you a contact for the akebono decals if you are using them, I was torn between black or white decals
Hth
Paul
If you're tight on budget you can still go for the Brembo's.
http://www.350z-uk.c...rs-for-350z-gt/
To be honest, unless you're planning a big supercharger / turbo install, makes no sense to upgrade to BBK, save some money for other upgrades :)
Some interesting advice there...
Incidentally I'm surprised to see that you don't need to alter any of the brake hydraulics replacing the JDMs with a different / larger brake kit. Also why do 350z "big brake kits" not come with increased rotor diameter and 4-pots for the rears? They all seem to be front-only.
Usually 6/8 pot fronts and 4 pot rears. It's just usually the fronts that people do first as they're more important. I'm pretty sure most of the main BBKs come front and rear.
Hth
Paul
You make it sound so simple Paul, they look great, I think I will give it a go. Akebono decals would be super.....oooo black :cloud9:
Edited by Ceejay29
