Battery upgrade
GT4 Zed
I measured the inside of the battery tray earlier & it measures 260mm maximum. So how are some of you fitting a 278mm battery in there? Am I to assume you've just sat it on top of the box, used the tie down strap & just hope it doesn't move?:wiggle:
Thanks for all the replies. As I didn't want to hack away at the battery tray, I bought a Yuasa 027AGM from work & it dropped right into the tray with no modification required. It's a little wider, but not as tall. It has 680CCA & 60Ah. Spins the engine over much better than the old RAC / Exide 005 that was in there.
