bpmjames Posted January 25, 2014 Share Posted January 25, 2014 Hey guys Wondering if anyone could shed some light on what I think is an issue. Had my zed for almost a year now and loved driving it when I got it but of late it seems to have become unresponsive and heavy feeling, like it's holding back. It's an 04 plate with plenum spacer, cossie filter, sports cats and Gemini. Exhaust. Is there anything obvious I should be checking first? Ignition timing, fuel starvation, plugs? It also smells really rich when I boot it. Any help appreciated! Jim Sent from my C6603 using Tapatalk Quote Link to comment Share on other sites More sharing options...
glrnet Posted January 25, 2014 Share Posted January 25, 2014 Check the air filter for starters. Quote Link to comment Share on other sites More sharing options...
bpmjames Posted January 25, 2014 Author Share Posted January 25, 2014 Cleared it the other day mate Sent from my C6603 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Lexx Posted January 25, 2014 Share Posted January 25, 2014 Any other symptoms when driving? Stuttering? hesitation? stalling? Misfire? What's the condition of the throttle body? Worth giving that a clean inside. Quote Link to comment Share on other sites More sharing options...
bpmjames Posted January 25, 2014 Author Share Posted January 25, 2014 No other symptoms really it seems pretty normal on that front just slow. I'll have a look at the throttle thanks Sent from my C6603 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Lexx Posted January 25, 2014 Share Posted January 25, 2014 Check for any stored ECU codes. If clear, do a ECU and throttle body reset. The process for all 3 of the above is in the Guides section Quote Link to comment Share on other sites More sharing options...
bpmjames Posted January 25, 2014 Author Share Posted January 25, 2014 Saying that when it's cold and u fire it up its a bit stuttery on low revs for a couple of mins Sent from my C6603 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Neilp Posted January 25, 2014 Share Posted January 25, 2014 Is you traction control kicking in at all? Roads are slippy these days. Also with those mods, have you had a remap done? 1 Quote Link to comment Share on other sites More sharing options...
glrnet Posted January 25, 2014 Share Posted January 25, 2014 Check the plugs and as Lexx says check for codes too, could be a coil pack playing up intermittently. 1 Quote Link to comment Share on other sites More sharing options...
gareth29 Posted January 25, 2014 Share Posted January 25, 2014 try driving diesel people carrier for a while - your zed will feel fab, i guarantee 2 Quote Link to comment Share on other sites More sharing options...
bpmjames Posted January 25, 2014 Author Share Posted January 25, 2014 Is you traction control kicking in at all? Roads are slippy these days. Also with those mods, have you had a remap done? Traction control doesn't kick in. Should have said it's been mapped Surely if it was throwing up a code the eml would be on? Sent from my C6603 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Dynamic Turtle Posted January 25, 2014 Share Posted January 25, 2014 From the title it sounds like you might need zinc supplements and a certain blue pill... Quote Link to comment Share on other sites More sharing options...
Keyser Posted January 25, 2014 Share Posted January 25, 2014 As above plugs, then give the MAF a clean, throttle body reset won't hurt then see how she is. Quote Link to comment Share on other sites More sharing options...
Neilp Posted January 25, 2014 Share Posted January 25, 2014 What fuel are you running also? Quote Link to comment Share on other sites More sharing options...
bpmjames Posted January 26, 2014 Author Share Posted January 26, 2014 I've reset the ecu but no change. The throttle reset didn't seem to work. I always use vpower nitro Sent from my C6603 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Lexx Posted January 26, 2014 Share Posted January 26, 2014 Does it rev freely in neutral? No stuttering or flat spots? Long shot, but check that non of your brakes are seized on. Quote Link to comment Share on other sites More sharing options...
bpmjames Posted January 26, 2014 Author Share Posted January 26, 2014 Yeah it seems to be fine mate. That's a good list of things to check I'll make a start on it during the week. I remember on my old 200sx it used to feel similar when the ignition timing was out slightly. Is there anyway it can change on the de engine? Sent from my C6603 using Tapatalk Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted January 26, 2014 Share Posted January 26, 2014 From the title it sounds like you might need zinc supplements and a certain blue pill... Quote Link to comment Share on other sites More sharing options...
Lexx Posted January 26, 2014 Share Posted January 26, 2014 Yeah it seems to be fine mate. That's a good list of things to check I'll make a start on it during the week. I remember on my old 200sx it used to feel similar when the ignition timing was out slightly. Is there anyway it can change on the de engine? Sent from my C6603 using Tapatalk VQ engines are chain driven. Unlikely for the timing to slip. Quote Link to comment Share on other sites More sharing options...
bpmjames Posted January 26, 2014 Author Share Posted January 26, 2014 The base timing is chain driven but the ignition timing is usually determined by a cam or crank sensor Sent from my C6603 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Mike1989 Posted February 7, 2014 Share Posted February 7, 2014 Get your timing checked, as unlikely everybody seems to think its that I had the same issues and it was that! Quote Link to comment Share on other sites More sharing options...
bpmjames Posted February 8, 2014 Author Share Posted February 8, 2014 Thanks Mike I'm assuming u mean the chain yeah? It rattles at start up from cold for a couple of secs which I am assuming is the cam chain tensioner Sent from my C6603 using Tapatalk Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted February 8, 2014 Share Posted February 8, 2014 Thanks Mike I'm assuming u mean the chain yeah? It rattles at start up from cold for a couple of secs which I am assuming is the cam chain tensioner Sent from my C6603 using Tapatalk http://www.350z-uk.com/topic/80271-timing-chain/ Quote Link to comment Share on other sites More sharing options...
Mike1989 Posted February 8, 2014 Share Posted February 8, 2014 Yeah my tensioner was knackered, worth checking the timing just to rule it out. Hope its not for you as its a pretty big job! Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted February 8, 2014 Share Posted February 8, 2014 Coil pack breaking down under load. Quote Link to comment Share on other sites More sharing options...
