Prototype strut brace test fitted pics
Tarmac@TarmacSportz
Fitted fine on Arran's DE with spacer. However with mine, it required a bit more work. It will be fine if you do not have polished tubes like my Injen does. So standard intakes and silicon hosed intakes are fine. Supercharged and Stillen/Injen polished intake tubes, it will fit, but it's really tight so you may end up damaging your polished bits.
How much room was there between the top of the strut and the bonnet when shut? You could potentially put a spacer to lift it a wee bit.
Would be easy to work out with thin layers of cardboard, just keep layering it until it dents when you close the bonnet.
Translated from Canadian to English.... :stir::teeth:
