pink head light bulb
keiran D
Morning all,
Had a search but could not really find anything definitive. A few days ago my my brother noticed one of my headlights was shining pink, the next day it was not on at all, side light still worked fine but main bulb is out.
Its a 2006 rev up, how often is it just the bulb? The pink light for a few hours has made me unsure!
Thanks
HID's do and will stil go, but nowhere near as often as a regular bulb.
A ballast fault would likely show itself as an instant change, one day its fine, the next day its pink, but a blown bulb would probably be a gradual change.
  • 3 weeks later...
I'm confused as to what model car I even own to be honest and that's not helping in figuring out right bulb!
I was sold it as a 2006 rev up, but Im unsure on how to tell if it is or a 276. I'm probably being really thick but any sure fire ways to tell?
If the hazard button is in front of the gear stick, you have LED rears and 4 orange LEDs on the side of your headlamps it'll be a 296 facelift using D2S bulbs. If the hazard button is behind the gear stick near the heated seat switch and you have orange reflectors on you headlights, it'll be a pre 2006 and require D2R bulbs.
Looks like I have a pre 2006 then! Not really bothered as at least it means I should not have the oil consumption issue.
Thanks for clearing that up boys.
on the down side your paying double tax. not all facelifts have issues btw. Mines is a facelift and uses no oil at all.
