parello9 Posted January 22, 2014 Share Posted January 22, 2014 Basically has anyone rolled their arches them self? I have borrowed the machine off a friend and was thinking of giving it a go, as i haven't payed and i know its about £90 done with archenemy He done his but rushed it, as it was a old car and split the paint I of course do not want this to happen so just wondering if people have any tips if they have experience Quote Link to comment Share on other sites More sharing options...
Daryl Posted January 22, 2014 Share Posted January 22, 2014 I think the general opinion is to take your time, and makesure that you use a heat gun to warm the paint up when you are rolling them. Im sure come a more decent hour someone else will be able to offer a much more informed opinion. Quote Link to comment Share on other sites More sharing options...
parello9 Posted January 22, 2014 Author Share Posted January 22, 2014 yeh thats what i have been looking up on youtube is just keep the heat.. Guna have to keep more heat though seeing as its so cold outside as well Quote Link to comment Share on other sites More sharing options...
ddcboyle Posted January 22, 2014 Share Posted January 22, 2014 Can i just ask, whats the point in rolling the arches?Something to do with tyre size? Quote Link to comment Share on other sites More sharing options...
parello9 Posted January 22, 2014 Author Share Posted January 22, 2014 I just want to do it so that if i hit a big pot hole the tire wont get shredded by the sharp lip hanging out Quote Link to comment Share on other sites More sharing options...
ddcboyle Posted January 22, 2014 Share Posted January 22, 2014 I just want to do it so that if i hit a big pot hole the tire wont get shredded by the sharp lip hanging out Ah ^^ Makes sense, ty Quote Link to comment Share on other sites More sharing options...
parello9 Posted January 22, 2014 Author Share Posted January 22, 2014 I just want to do it so that if i hit a big pot hole the tire wont get shredded by the sharp lip hanging out Ah ^^ Makes sense, ty yeh i used to never understand it but now i see why lol!.. Quote Link to comment Share on other sites More sharing options...
KyleR Posted January 22, 2014 Share Posted January 22, 2014 Put 3 fat mates in the boot, does the tyre rub? If it doesn't rub then, you'll not need to roll Anyway, I can only echo what others have said, keep plenty of heat on it and take your time. Mate done mine for me whilst it was in a body shop for a lick of paint anyway, so if something went wrong it was in the best place for it. Went fine though Quote Link to comment Share on other sites More sharing options...
Spatt Posted March 17, 2014 Share Posted March 17, 2014 my mate did this and said you should cut the paint with a sharp blade on the inside where you cant see it. it helps to stop the paint cracking. You might want to find some more info on this though? think it only really matters if your going to flare them. Just make sure you heat em up Quote Link to comment Share on other sites More sharing options...
docwra Posted March 17, 2014 Share Posted March 17, 2014 Yeah, unless you are running no standard wheels you shouldnt have a problem. Id add that while the fronts are pretty easy the rears are known for being deadly, if mine needed doing Id be straight on the blower to Archenemy Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted March 17, 2014 Share Posted March 17, 2014 I slit my rears with an angle grinder and then heated and bent the tabs up Quote Link to comment Share on other sites More sharing options...
d95gas Posted March 17, 2014 Share Posted March 17, 2014 I have the full arch rolling kit that used to get hired out when I was on the MR2 forums, I reckon that at least 40 cars had been done and all followed the simple principle of gentle heat and take your time. You can roll the arch which will push that 20 - 25mm lip back and flat against the inner wing, or you can also continue and do a flare if you need more clearance. Other tips I always offered were: Before you start give the inner lip a thorough cleaning, and make sure its sparkling clean, then give it a good coat of something like wheel wax. Once you have rolled the lip up, use some clear silicon sealant and seal the gap between the edge of the lip and inner wing, you want to prevent water/crud/mud getting trapped between the U that you've just created. Apply gentle heat and only work on the heated area Take your time.......cannot stress the importance of this, otherwise you could end up causing damage, last thing you want is to have a spray job done on the damaged areas. Everyone who hired the kit followed these simple guidelines and everyone successfully completed the job. HTH 1 Quote Link to comment Share on other sites More sharing options...
Spatt Posted March 17, 2014 Share Posted March 17, 2014 yeh what he said and good idea with the silicone.. wet mud sat in that area will just rot your arches from the inside out so take your time in cleaning it all out Quote Link to comment Share on other sites More sharing options...
