Heated door mirrors not working
ianboom
Firstly, apologies if I've posted in the wrong area, I've been a member for a while, but not had a zed or posted for months!
Anyway, I have a '54 plate 350Z that the heated rear mirrors are not working on. I'm pretty good with electrics and have found no power at the fuse by the gas pedal.
Does anybody have a wiring diagram for the car or know where the fuse is fed from?
Also, is the Haynes manual any good or should i look elsewhere?
Thanks, Ian.
Sorted for now!
Found the relay where the subwoofer would sit (mine's a non GT-what a huge waste of space!) but it was ok, Deciphered the wiring diagram and checked the body control module (when i eventually found it) and the 20a supply fuse had blown.
Put a new fuse in and it seems fine at the moment, Find it strange the 20a fuse went and not the 10amp inside the car=if I have no more problems, all i can assume is somebody swapped the fuse with another for some reason?
Will have to put the car back together at work tomorrow as I have a strip of plastic from around the battery that i can't find a home for!
Ian.
