front wheel bearing
GT52
Hi
Had both my front bearings replaced a few months ago.
I have a 53 JDM and the bearings of UK 350z are exactly the same as my JDM, not to sure about the 52, but I'd say they are the same.
Dealer added an extra £30 per bearing when my garage ordered them saying they had to be imported! I told the my garage to check the item number they had on the packaging and this number was the same as UK item number for bearings.
Guys at garage I use rang dealer and told them they wanted the £60 (30 each) as they were not imported at all and were in fact the UK bearings.
Dealer had the cheek to say that, because my car is an import, they can charge what they like!!
Needless to say, my garage got their money back after they said they'd get in touch with Nissan GB!
If I were you I'd try and find the item number for bearings on your 52 model and check it against the UK version. I'm sure you'll find they are the same.
Dont let the dealer get away with charging you more just because you have an import.
Cheers
Josh
