Oil & filter change
Carr
Hello! Got my Z on Sunday! :)
I need to change the oil & filter this Saturday, I am away until then so I have no access to the owners manual...
Can anyone reccomend to me as to what oil to put in the car?
Is it 5W30 Fully synthetic? (I have been reading in the forum lol)
Any brands?
Thanks,
Nathan
350Z Fluids Recommendation Data
Nissan, 350 Z, 350 Z / Fairlady Z, 2004- [Preliminary Info]
Manufacturer: Nissan Motors Co., Ltd., Tokyo, Japan
Drive type: r.w.d.
Cylinder capacity: 3498 cc
Power output: 280 HP/206 kW at 6200 RPM
Engine VQ35DE
Petrol, 4-stroke, 6 cylinder, V, 4 valves/cil., liquid cooled
Power output: 280 HP /206 kW at 6200 RPM
Capacity:
4.7 liter
Overhaul capacity: 5.4 liter
Filter capacity: 0.3 liter
Use: normal - OEM recommendation
Below 15 API: SL SAE 5W-30
Above -20 API:SL SAE 5W-40
Above -20 API: SL SAE 10W-30
Above -20 API: SL SAE 10W-40
Above -20 API: SL SAE 15W-40
Below 15 ILSAC GF-2 SAE 5W-30
Above -20 ILSAC GF-2 SAE 5W-40
Above -20 ILSAC GF-2 SAE 10W-30
Above -20 ILSAC GF-2 SAE 10W-40
Above -20 ILSAC GF-2 SAE 15W-40
Transmission, manual, 6 speed
Manual
Capacity: 2.9 liter
Gears forward: 6
Gears reverse: 1
year-round API: GL-4 SAE 75W-85
Differential, front, limited slip
Capacity: 1.4 liter
year-round API: GL-5 LS SAE 80W-90
Use only limited slip hypoid gear oil which is approved for Nissan LSD.
Transmission, automatic
Automatic
Gears forward: 5
Gears reverse: 1
year-round Special ATF, Nissan -
OEM recommends Nissan Matic J ATF.
Hydraulic brakes/clutch system, ABS
Use: normal - OEM recommendationyear-round Brake fluid, DOT 3 -
year-round Brake Fluid DOT 4+ -
Never mix different types of fluids.
Power steering
Capacity: 1 liter
year-round Dexron III -
Grease points/nipples
year-round Lithium base multipurpose grease NLGI No. 2
Cooling system
Capacity:
7.9 liter
Reservoir: 0.8 liter
year-round Nissan Anti Freeze Coolant (L250) -
