AJRFulton Posted January 12, 2014 Share Posted January 12, 2014 (edited) My Z constantly gets internal condensation. Tried everything to stop it. Leaving the windows open on dry days, keeping it in a garage with windows open over night.... but still constant condensation whenever it is parked up for a while. I come back to the car and there are actual drops of water on the inside of the windscreen, as well as mist on all windows. There is no obvious dampness or leaks in the car. Is this a common trait with Z's? Does anyone have any idea how to stop it? I'm getting fed up having to wait 5 minutes for my windows to demist, and the droplets to evaporate every time I start her after she's been stting for a few hours. Honestly, I've never had a car like this for condensation build up. Edited January 12, 2014 by AJRFulton Quote Link to comment Share on other sites More sharing options...
Commander Posted January 12, 2014 Share Posted January 12, 2014 It's a common feature of all Zeds. Most leave the air con on all the time as its also a de-humidifier, but even that's not enough in this weather really and we all end up doing exactly what you are already doing. Alternatively you could try sticking one of those chemical desiccant things in your car, might help soak up the moisture a bit more... Quote Link to comment Share on other sites More sharing options...
sipar69 Posted January 12, 2014 Share Posted January 12, 2014 I even get a small amount on the inside of the sat nav screen occasionally! Disappears when the car warms up though, Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted January 12, 2014 Share Posted January 12, 2014 Well known fact that Zeds are bad for condensation, I run the air con all the time and stuck a bag of silica gel in the boot, seem to work, but still have to demist before setting off, takes a while, but no great problem. Quote Link to comment Share on other sites More sharing options...
Ebized Posted January 12, 2014 Share Posted January 12, 2014 Need to use the air con and screen defroster button more, by the sound of it - see the handbbook - (page 4.28 for 2011 models) And yes, silca sachets will help to remove excess buildup of mositure that should be overcome by regular use of the a/c Oh, and make sure the two cabin sensors are not covered over. If the problem still persists the a/c may need recharging - again that may be down to lack of use throughout the year, Quote Link to comment Share on other sites More sharing options...
Stutopia Posted January 12, 2014 Share Posted January 12, 2014 I recently dropped one of these in the "footwell" behind the driver's seat. http://www.amazon.co.uk/dp/B0027IXYGA/ref=pe_385721_37038051_pe_217191_31005151_3p_M3T1_dp_1 Cuts down condensation nicely when I get in, but does require "recharging". If I was doing it again I'd probably find a 1kg bag instead of 500g and order two, for squad rotation or, because yours seems really serious, one behind passenger seat as well. Other than that, crank your AC as per above. Good luck. Quote Link to comment Share on other sites More sharing options...
ioneabee Posted January 12, 2014 Share Posted January 12, 2014 1st time I've heard this happening with the 370 though mine (at the moment) is fine (famous last words) Quote Link to comment Share on other sites More sharing options...
Will370z Posted January 12, 2014 Share Posted January 12, 2014 Same here Andy I don't get this problem and never had water build up on the inside Quote Link to comment Share on other sites More sharing options...
Wayne370Z Posted January 12, 2014 Share Posted January 12, 2014 Can`t say that I`ve ever had more than the normal/expected bit of misting up - certainly no water droplets inside and it`s just out in the cold on the drive overnight. Quote Link to comment Share on other sites More sharing options...
AJRFulton Posted January 12, 2014 Author Share Posted January 12, 2014 My aircon is almost never off. Shouldn't need recharging after 14k. Glad to know it's a known issue, honestly never had a car that gathers condensation like the Z. Above the instrument dials on the windscreen is where it's worst. As said it's went beyond mist and is actual water droplets Quote Link to comment Share on other sites More sharing options...
ioneabee Posted January 12, 2014 Share Posted January 12, 2014 AJR - its definately a 350 problem - but this is the 1st the 370 owners have seen this Quote Link to comment Share on other sites More sharing options...
HARMLU Posted January 12, 2014 Share Posted January 12, 2014 (edited) Well known issue. On my 350z (am I right in saying yours is a 370z), the windows most up very quickly when it is wet outside. I've just brought a 500g bag of silica beads so when I leave the car under the cover, I'm hoping they should get rid of some of the moisture. Having said that, the air con should remove moisture very quickly anyway! Edited January 12, 2014 by HARMLU Quote Link to comment Share on other sites More sharing options...
Sharpen Posted January 12, 2014 Share Posted January 12, 2014 Above the instrument dials on the windscreen is where it's worst. As said it's went beyond mist and is actual water droplets Mine is the same in this cold weather, I just keep a microfiber cloth in the car to wipe this up, and then the windscreen button on plus full fan clears the mist in a minute or so. Quote Link to comment Share on other sites More sharing options...
350zedd Posted January 12, 2014 Share Posted January 12, 2014 If its really chronic, you could try a small heater in there on the back shelf. Say a 45w tubular or similar. You'd have to be near a socket outlet though and get the cable through into the car. It sounds a bit OTT but might prevent the inside glass surfaces falling below dewpoint. Never tried it myself.....just thinking about it. OR wedge a flat piece of cardboard against the glass to keep the air off Quote Link to comment Share on other sites More sharing options...
gareth29 Posted January 12, 2014 Share Posted January 12, 2014 Similar problem on my 350 - going to try only running it on recirculate with the ac on see if that makes a diff. Mind you the ac only works with ambient temps above 6 degrees? Also, saw a product in the latest evo which was aimed at this problem - "rain-x anti-fog", it cured the problem with the journo's car, but took 2 applications. Quote Link to comment Share on other sites More sharing options...
bronzee Posted January 13, 2014 Share Posted January 13, 2014 We don't have that issue over this side of the pond, and in summer here gets extremely humid and winter very damp. Air con all the time though. Big enough engine to cope with having the air con on. Quote Link to comment Share on other sites More sharing options...
