Aglii Posted January 12, 2014 Share Posted January 12, 2014 (edited) I guess alot of people would like to do this, looks waaaay better then the ones you can buy, and also the ones you buy are really expensive.. http://my350z.com/fo...nfsp-style.html This is not a complete list but it help a bit. Its from my350z, you can find all this in your local hardware store. Unless otherwise listed, everything is 1.00 pitch. plenum 9 m6x25mm 3 m6x40mm 4 m6x60mm 2 m6 nuts 6? m6x16mm plenum w/ spacer (from motordyne doc) 11 m6x35mm 3 m6x55mm 4 m6x70mm 18 m6 washers strut 6 m10x1.25x30mm (motordyne/) 8 m10 washers 2 m10x1.25 nuts 6 m8x1.25 nuts radiator support 4 m8x1.25x20mm 4 5/16 counter-sunk washers throttle body 4 m6x60mm of these 4 m6 flat washers - chrome power steering 3 m6x30mm Misc 100pk #12 counter sunk washer 100pk 1/4" counter sunk washer 10ish m6 flat washers 10ish m8 flat washers 10ish m10 flat washers 10ish extra m6x25mm 10ish extra m6x16mm Edited January 12, 2014 by Aglii 1 Quote Link to comment Share on other sites More sharing options...
Aglii Posted January 12, 2014 Author Share Posted January 12, 2014 (edited) This IS a complete list for the HR! This is for the HR motor, but much of it is the same for DE cars as well Headlights (2) M6x1.00x20mm flat head allen bolts (2) M6 countersunk washers Strut Bar (6) M10x1.25x25mm flanged hex bolts (use 30mm if you have a DE with a plenum spacer) (2) M10x1.25 flanged nuts (8) M10 flat washers Shock Towers (6) M8 flanged nuts (6) M8 flat washers Power Steering Bolts (3) M6x1.00x25mm flat head allen bolts (3) M6 countersunk washers Radiator Support (4) M8x1.25x20mm flat head allen bolts (4) M8 countersunk washers Engine Cover (HR specific two piece cover) (3) M6x1.00x20mm flat head allen bolts (3) M6 countersunk washers (4) M6x1.00 dome(acorn) nuts (4) M6 flat washers Hood (4) M8 hex nuts (4) M8 flat washers Throttle Body (for DE motors, get 4 of each and the bolt are 60mm in length instead of 55) (8) m6x1.00x55mm metric allen bolts (8) m6 flat washers (the smaller the outside diameter the better) Fender (6) M6x1.00x25mm flat head allen bolts (6) M6 countersunk washers (4) M8x1.25x20mm flat head allen bolts (4) M8 countersunk washers 104 total pieces. Edited January 12, 2014 by Aglii Quote Link to comment Share on other sites More sharing options...
RDON Posted January 12, 2014 Share Posted January 12, 2014 hmm think I might see if I can source all these and bling up my bay! 1 Quote Link to comment Share on other sites More sharing options...
