zed 1990 Posted January 11, 2014 Share Posted January 11, 2014 hi guys, my theme is carbon blue and chrome/polished metal what you got ? Quote Link to comment Share on other sites More sharing options...
Aglii Posted January 12, 2014 Share Posted January 12, 2014 (edited) Aluminium bolts with blue washers: http://www.epracing....p-848-844-3162/ Weapon R ps resovoir: http://www.tarmacspo...6-121-101_.aspx Weapon R, collant resovoir: http://www.tarmacspo...6-123-101_.aspx Aluminum oil cap: http://www.tarmacspo...0Z-400700_.aspx Grounding kit(not sure if its seen though: http://www.tarmacspo...350zGROUND.aspx Engine damper: http://www.tarmacspo...9-111-410_.aspx Carbon bonnet damper: http://www.350z-uk.c...mpers-75-deliv/ Carbon engine cover: http://www.epracing....5-122-123-1442/ Carbon brake and battery cover: http://www.epracing....5-122-123-1443/ Carbon cooling plate: http://www.epracing....5-122-123-1448/ blue hoses: http://cougarstore.c...&products_id=75 This is a good start Then also a Cold air intake, with a carbon or aluminium heatsheild Edit Forgot to mention polished plenum, thats a BIG part You can either buy it for some big money, do it your self or pay someone to do it for you. You can find DIY "How to polish a plenum 350z" Edited January 12, 2014 by Aglii 2 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted January 12, 2014 Share Posted January 12, 2014 Definitely recommend a set of carbon fibre bonnet lifters/struts from 14N. Mine came with blue stickers on them too which keep in your colour scheme. Check them out here; http://www.350z-uk.com/topic/79733-fs-i-have-some-more-350z-carbon-bonnet-dampers-75-deliv/ 2 Quote Link to comment Share on other sites More sharing options...
Aglii Posted January 12, 2014 Share Posted January 12, 2014 You can also do the aluminium bolts and washers yourself here is a good DIY http://my350z.com/forum/body-interior-exterior-and-lighting-diy/543864-diy-engine-bay-dress-up-bolt-washer-kits-nfsp-style.html Quote Link to comment Share on other sites More sharing options...
GMballistic Posted January 12, 2014 Share Posted January 12, 2014 ^^ Good shout ~ I've got lot's of stainless steel bolts in my engine bay to get rid of the nasty OEM rusty Nissan ones. 1 Quote Link to comment Share on other sites More sharing options...
Almeida1234 Posted January 12, 2014 Share Posted January 12, 2014 Wwwwwwow I need to look in to these bits 1 Quote Link to comment Share on other sites More sharing options...
Aglii Posted January 12, 2014 Share Posted January 12, 2014 Yes seems pritty straight forward this DIY Also look 30x better then the ones you can buy http://www.nfspmotorsports.com/forum/MGalleryItem.php?id=1790 Quote Link to comment Share on other sites More sharing options...
14N Posted January 12, 2014 Share Posted January 12, 2014 Wow, thanks for the double mention guys, but the OP already has a set of my dampers Aglii that quite a list there! I may have to take a look through that myself 2 Quote Link to comment Share on other sites More sharing options...
