Help with sorting error codes
Cookiebear
I've had 4 warning lights come on on the dash since just before Christmas. Finally got a chance to get it diagnosed yesterday and was given a list of the following error codes;
P1805 Brake switch improper signal
P0345 Camshaft position sensor problem bank 2
ABS
C1142 ABS Pressure sensor circuit
C1109 Battery voltage out of range
Hoping someone else might have had something similar and got it fixed.
I was thinking of replacing the brake switch and Camshaft sensor as well as a new battery. See what this does and take it from there.
All suggestions welcome to solve these issue.
I am asumming that your car is running okay ????
If so, keep a note of the codes and then clear them as some of them may be archived codes.
If EMS comes back on, then pull the codes again and post back up here and I will advise further.
Alex. :)
