Missfire cylinder 1 p0301
Y23DRH
So the zed had the engine light come on had code read p0301 come up
Replaced all spark plugs Still the same :/
Every coil pack replaced still the same :/
All imjectors injectors and still have a misfire on number one cylinder :/
The cars also had service all items changed etc running out of ideas now any one ???
Suggestions welcome :)
Its 2005 350z gt roadster
Have you done any engine mods without a remap?
Nope had all mods done and had it remaped
But i do have a new maf sensor tho but cant see that being the culprut as was there before that was fitted :/
My mechanic is doing a compresssion test tonight will update once i have the results from it :/
Edited by F4ABP
Cars fixed several hours later took out plugs and coils and did compression test
6th 160
4th 155
2nd 165
5th 150
3rd 150
1st 160
Compression test results. Not sire if low or not tho ??
Cleaned every thing up re read the codes and cleared them put it all back together
Fired up spot on no misfire at all no eml light and no codes showing drives perfect and is alot quicker now the eml light is off big thanks to every one for there advice :)
