Payco Posted January 8, 2014 Posted January 8, 2014 Want to purchase and fit an engine start button on my 350z like the 370z. I know a few forum owners have done this (WASSO for starters). Can someone point me in the direction of where i can purchase one and what the fitting instructions are. Thanks friends Payco Quote
Grundy Posted January 8, 2014 Posted January 8, 2014 Zed shed guys should be able to point you in the right direction, Try Buster or Keyser. Quote
AliveBoy Posted January 8, 2014 Posted January 8, 2014 (edited) Taaa daaaaaa: http://www.350z-uk.c..._+start +button :D Edited January 8, 2014 by AliveBoy Quote
Payco Posted January 8, 2014 Author Posted January 8, 2014 Thanks Aliveboy. You are a star. I searched the site but couldnt find anything. Thanks Pal Payco Quote
spursmaddave Posted January 9, 2014 Posted January 9, 2014 Nice but don't you still have to put the key in, turn it 90% of the way you would normally, then press the button To me that just makes it look even more added on than it already is Sent from the golf club... Quote
Payco Posted January 9, 2014 Author Posted January 9, 2014 Heard that you can wire it up so it disengages the main ket barrel. I agree with you Dave, there is little point in it if you still have to put the key in the barrel and turn it. Payco Quote
spursmaddave Posted January 9, 2014 Posted January 9, 2014 Heard that you can wire it up so it disengages the main ket barrel. I agree with you Dave, there is little point in it if you still have to put the key in the barrel and turn it. Payco But surely the key still have to be next to the barrel to 'pair' with it? If you could get it to work so you blip the door, pocket the key, get in, dip the clutch and press the button the fair play, anything else would just be silly in my book but there you go Sent from the golf club... Quote
Ian Posted January 9, 2014 Posted January 9, 2014 Heard that you can wire it up so it disengages the main ket barrel. I agree with you Dave, there is little point in it if you still have to put the key in the barrel and turn it. Payco But surely the key still have to be next to the barrel to 'pair' with it? If you could get it to work so you blip the door, pocket the key, get in, dip the clutch and press the button the fair play, anything else would just be silly in my book but there you go Sent from the golf club... I had mine wired at one point to start when the clutch was dipped Made changing gear hard though Quote
spursmaddave Posted January 10, 2014 Posted January 10, 2014 Heard that you can wire it up so it disengages the main ket barrel. I agree with you Dave, there is little point in it if you still have to put the key in the barrel and turn it. Payco But surely the key still have to be next to the barrel to 'pair' with it? If you could get it to work so you blip the door, pocket the key, get in, dip the clutch and press the button the fair play, anything else would just be silly in my book but there you go Sent from the golf club... I had mine wired at one point to start when the clutch was dipped Made changing gear hard though You almost invented the stop/start system there! Sent from the golf club... Quote
