Knocking bushing
HARMLU
I have a knocking bush on my daily. I replaced the drop links recently, so that leaves the suspension arm and ball joint.
What's a good lubricant to spray on the bushings to eliminate which one it is? I'm not sure if wd40 would cut the mustard?
Strange, I'm sure there was a spray which (i think) zmanalex suggested in another thread. It's not to cure the problem, it's just to eliminate whether it's a bush on the arm or the ball joint. I suspect it's the ball joint. And it's not the zed
If your after a really good grease then I thoroughly recommend Wurth HHS 2000 it sprays on like wd-40 so it penetrates all the places it needs too then after 30 ish seconds the solvent evaporates to leave behind a conventional high temperature grease. Easiest place to get some would be ebay.
If it is a knocking your hearing then I can't see any grease helping.
Edited by 350 Russ
