madmikester's 350z blade silver
madmikester
Ok so yesterday didn't go how I wanted
Gd points first got the services done all new fluids and also pressed two of the bushes in as for however
Found more bushes ****ed on the control arm and the ball joint will not budge out the hub at all need a hub press I think so bit stuck and still got the othetside to go :wacko: here's the pics
Sent from my HTC One X+ using Tapatalk 2
Yer brad for sure I'm off till end of may from Sunday so defo do it with u did mine when I got the car too and fly wheel call me n we can sort something out
Ok slight update ok so got the lower ball joints replaced
The adjustable camber arms on and all the banana arm bushes out
So on with the refit just need to drill one bolt out and the refit the suspension hope to be back up and running today :D
Massively impressive Mike! How hard was it to remove all the old bushes and did you have a special tool / press? Something I'm looking to do in the near future, but you look like you have about 1000x more mechanical skill than me! :)
Thanks and It's not to bad as long as u have the correct tools I didn't to start with so delayed everything the tools I have are a hydraulic press and a ball joint press which is amazing spent a day trying to remove them with no luck got the ball joint press 20 mins later all changed
If u need a hand when you do yours more than happy to help
update car is all back together now with all the from bushes replaced the lower ball joints and also adjustable camber arms and a fresh new mot all passed
Also boot is all packed ready to head over to bradders to fit his clutch and flywheel
