bobmac Posted January 1, 2014 Share Posted January 1, 2014 (edited) As title guys got a 53 plate and about 6 months back the front washers stopped working, turned out to be the non-return valve fitted in the line just behind the brake fluid container, they have now stopped working again checked the valve, its not getting any water and i cant hear the motor, before i rush out and buy a replacement pump, i thought id check the fuse first ( im assuming the front/rear washers work from seperate fuses) trouble is i dont know where the fuses are located any help appreciated thanks in advance Edited January 1, 2014 by bobmac Quote Link to comment Share on other sites More sharing options...
buster Posted January 1, 2014 Share Posted January 1, 2014 Drivers footwell Quote Link to comment Share on other sites More sharing options...
buster Posted January 1, 2014 Share Posted January 1, 2014 (edited) I do believe that the washer fuse is in the fuse box under the battery inspection cover in the black box.... top right, Edited January 1, 2014 by buster 1 Quote Link to comment Share on other sites More sharing options...
bobmac Posted January 1, 2014 Author Share Posted January 1, 2014 its not by the battery where abouts in the drivers footwell is the other fusebox to dark now anyhow will have to wait til weekend but many thanks for the replys guys its appreciated 1 Quote Link to comment Share on other sites More sharing options...
buster Posted January 1, 2014 Share Posted January 1, 2014 this may help ref my post Quote Link to comment Share on other sites More sharing options...
buster Posted January 1, 2014 Share Posted January 1, 2014 its not by the battery where abouts in the drivers footwell is the other fusebox to dark now anyhow will have to wait til weekend but many thanks for the replys guys its appreciated To the right of the throttle pedal behind the kick panel. Quote Link to comment Share on other sites More sharing options...
buster Posted January 1, 2014 Share Posted January 1, 2014 this may help ref my post The fuse for the front washer motor is #84. It's the 4th fuse down in the right hand column of fuses , rated at 10 amps. Quote Link to comment Share on other sites More sharing options...
Payco Posted January 3, 2014 Share Posted January 3, 2014 Is that a rust bonnet damper I see ?. Payco Quote Link to comment Share on other sites More sharing options...
bobmac Posted January 3, 2014 Author Share Posted January 3, 2014 Buster you are a god day off tomorrow will get on it and hopefully just a fuse, many thanks its appreciated mate Quote Link to comment Share on other sites More sharing options...
Neilp Posted January 3, 2014 Share Posted January 3, 2014 make sure you fill the bottle right up as mine stopped working and it was because the bottle was empty even though the wipers had water Quote Link to comment Share on other sites More sharing options...
buster Posted January 3, 2014 Share Posted January 3, 2014 Buster you are a god day off tomorrow will get on it and hopefully just a fuse, many thanks its appreciated mate your welcome . hope you sort the problem. Quote Link to comment Share on other sites More sharing options...
bobmac Posted January 5, 2014 Author Share Posted January 5, 2014 bugger turns out the fuse was OK and the washer bottle is full, got to be the washer pump, so next how do I find it and replace it Quote Link to comment Share on other sites More sharing options...
buster Posted January 5, 2014 Share Posted January 5, 2014 Try the traders on here ie zed man Alex.....or Euro car parts Quote Link to comment Share on other sites More sharing options...
bobmac Posted January 5, 2014 Author Share Posted January 5, 2014 sorry buster perhaps didn't explain myself properly I meant where abouts under the bonnet is the damned pump located Quote Link to comment Share on other sites More sharing options...
glrnet Posted January 5, 2014 Share Posted January 5, 2014 Attached to the bottom of the washer bottle, think you have to take the wheel arch liner off to get to it. Have you checked the non return valves? Quote Link to comment Share on other sites More sharing options...
ZEUS Posted January 5, 2014 Share Posted January 5, 2014 When you get to the pump put power directly to it to make sure it's the pump bust and not a broken wire somewhere 1 Quote Link to comment Share on other sites More sharing options...
glrnet Posted January 5, 2014 Share Posted January 5, 2014 If you need the pump:- http://www.eurocarparts.com/universal-12volt-washer-pump Quote Link to comment Share on other sites More sharing options...
glrnet Posted January 5, 2014 Share Posted January 5, 2014 This might help too:- Quote Link to comment Share on other sites More sharing options...
bobmac Posted January 5, 2014 Author Share Posted January 5, 2014 valves ? thought there was just the one behind brake fluid container ? last time happened to be that one, checked that one and no water and I cant hear the pump when listening from under the bonnet, checked the fuse, thought id read somewhere that you have to remove the under tray and inner wing on the drivers side to access the pumps, just wondered if anyone had done a "how to guide" for idiots like me Quote Link to comment Share on other sites More sharing options...
Jay M1988 Posted January 26, 2014 Share Posted January 26, 2014 Bobmac can you help me locate this fuse please, is it the same location in the video or is ours in the footwell itself. I've seen the fuses near the accelerator but can tell which is 84? Any helps welcome mate Quote Link to comment Share on other sites More sharing options...
bobmac Posted January 27, 2014 Author Share Posted January 27, 2014 its definatly the one in the video mate you have to remove the cover that surrounds the battery ( clips just pop out easy) and its the fusebox at the back behind the battery, turns out its my pump and not the fuse damn Quote Link to comment Share on other sites More sharing options...
Jay M1988 Posted January 27, 2014 Share Posted January 27, 2014 (edited) Cheers dude I'm the same just checked an fuse is fine, so new pump me thinks ill have to get hunting now Edited January 27, 2014 by Jay M1988 Quote Link to comment Share on other sites More sharing options...
