Hel brake lines
HAMLNJ
Apparently there's been some issues with getting the banjo connectors to seal properly on the calipers. Not everyone has that problem though. Newer hel lines have a modified connector for the caliper that gets rid of that issue. Other lines are available :)
Only ever had the problem with 1 set (I have fitted a few for owners) It's more the casting on the back of the Brembo that does not seal - you will know as soon as you try to bleed them if they have a poor seal.
HEL lines are fine, better than stock and I'd trust them no end more than any brand I don't know.
I don't know the names of the various fittings but if you give CS a pm with the measurements and what ends you have he will probably have a set in stock that he could check against for you :thumbs:
