Locked Out HEEEELLLPPP
Lyger
I took a wise decision to take my 2002 350z off the road this winter as it needs bits of body work doing,and the brakes and the broken door lock (Works fine with the remote but not with the key!!)
Ive been running the car for an hour or so every couple of weeks to stop things seizing up and to keep the battery topped up, however today it seems the battery has died and i cannot open the doors, the manual lock doesnt work the plastic clip holding the arm has snapped so as you turn the key in the lock it just rattles about.
Is there any way i can get the door open without breaking the window ?
Thanks
Yeah I cant get in to do anything its locked with all the windows up - I took the car off the road and cancelled my insurance and breakdown cover as i diddnt think id be needing it while the spring next year.
Edited by Lyger
PM Buster or Keyser at The Zed Shed, I'm sure he will have an idea, or Zmanalex may be able to help. :pmzmanalex:
Edited by WhackyWill
I thought i might be able to feed a tape measure with a hook on it to grab the door release but it was worse than trying to get a teddy out of those grabber machines at the fair.
If i could get the bonnet up i could charge the battery and open the doors , um my jack is in the car. anyway of popping this from the front and if i did this from the underneath how do i release it?
Its a pity there isnt an emergency charging point underneath somewhere.
Do what I said and PM the Zed Shed boys and Alex and see if they have a solution. they are the experts. :thumbs:
call out a locksmith, they will stick an airbag in between the glass and the window frame and then inflate it, this will crate a gap big enough for them to reach through with a tool and unlock the door then open it.
or get down to Wickes and buy one of these, it's known in the industry as a professional window opener:
Edited by AliveBoy
  • Like 2
If you google "how to break into a 350z" Lyger there are quite a few threads/solutions depending on what people have done to lock themselves out of the car. This is just one I found on www.350zTech.com;
i locked mine in once and when I had the locksmith come I realized how easy it was and that it is not worth it to lock the 350Z, all he did was pry the window slightly back where the front pillar meets the roof, put a wooden wedge to hold it and stuck a wire or rod down to hit the unlock button and done.
Hope you get it sorted either way. Good luck. :thumbs:
