GT4 zed build - project bumblebee
GT4 Zed
The Drivetrain
JWT HD clutch. Should hold 500lbft
JWT Lightweight single mass flywheel. Improves response but makes a racket. Not an issue now as the SC and LSD drowns itðŸ˜
Chromoly clutch pivot ball. The OEM wear down eventually and especially with uprated an clutch
Nismo needle pilot bearing. Nismo knows best so who am I to use the brass bearing.
Drivetrain ready to revived uprated goodies.
All fitted.
Uprated the rubber clutch cable with a braided offering. This is Hel's. improve clutch feel and does not go mushy after track abuse.
Torque solution gearbox mount bushing compared to OEM
Gets rid of sloppiness in gear lever. Changes feel riffle sharp but only negative is the increase in NVH if you care about that. I don't!
Refurbing diff and Cusco LSD
Voila!
Cusco type RS 1 to 2way LSD
Within pumpkin
Split open to reconfigure plates and diff to 2 way and 60% locking.
I don't want to go into the long story of how we wasted for hours to set it as 1.5way only to find out that I had the 1-2way diff. Blame seller!! In any case I love the 2way setup. Enables stable braking into corners and higher entry speed and corner grip and early power on exit!
B&M short shifter.
Next interior
Edited by GT4 Zed
Awesome car love the look at the last pics, spoiler also looks nice i mean its after all for alot of track driving, its not what i would choose for a DD, and all those mods are crazy :D Wanna sell me the car for 10.000 pounds? :lol:
Also you are the definitly the most helpful guy i have talked to here, helped and adviced me ALOT, and when you have time put in interior pics, would love to see them :yahoo:
Thanks so much again!
See you in 2015 :p
Edited by Aglii
Thanks for the comments!
The rear wing is from RT performance and its made of carbon fibre so very light. It has a high and low downforce setting.
I can also remove it if I want to tone down the looks😎
I get the rest of the pics up soonðŸ‘
Short shifter is great! Had the japspeed on first but though it installed and worked ok it lasted maybe about a year and then disintegrated! B&M probably make one of the best short shifters. The nismo is too expensive when its essentially the same minus the adjustability. Got it from US👀
Didn't know octet had issues as he recommended the B&M as I was considering the more expensive TWM shifter.
  • 3 months later...
Awesome thread mate B)
I'm interested in some of the goodies you've put on your car as well, I'll only be doing about 3 or 4 track days a year but a couple of things I'd be keen to do.
I think I'd do that gearbox mount when I have my clutch flywheel done, and potentially the shortshifter - however, I'm guessing the standard knob won't fit afterwards ?
  • 1 year later...
