GT4 zed build - project bumblebee
GT4 Zed
Finally I've put together my build thread to share my journey with "bumblebee". I have had a very rich and varied drivers car history and between 2001 and 2008 I had owned 3 M3s(e30, e36, e46), Alpina B3.3 conv, e36 328i, 2 TVRs(4.5l V8 cerb LW,Tuscan mk1 S), lotus elise 111R, Bug eye STI with 550bhp, BS 350z coupe. I had got to the point I had to slow down and pick a platform to develop over time to my requirements and keep for longterm.
That platform came as the 350z. I had just lost 6k on the lotus buying from brand new after under 8 months of ownership. It was doing my back in so it had to go! I should have got a Sagaris - See their value now!
I went to my habitual performance shop to look at a stunning fully modded R34 to replace the lotus and in the end left with the 350z! I was smitten by its looks and the drivers involvement and could spot the potential. Up to that point i'd never seen or heard about a 350z before🙀
The R34 was +£40k but I was deterred by the fact I was buying a complete car and no room to build my own.
After under 6months of ownership and testing various limits I got my friendly dealership to source me the ltd edition GT4 in kuro! So the BS coupe was chopped in! My thoughts were if it was going to be a keeper it may as well be special edition and with a bit more power! About the same time I joined the forum here and the US. Best move too! I covered every material I could lay my hands on on both forums and the Internet so I knew what I had to do.
Everything mod was planned and staged and at the end I hoped she would end up a powerful, safe, reliable fast road and track GT car capable of under 8mins at the Ring. "Built not bought".
With objective set my journey began. I'm not done yet but almost there.
I also thought that rather than do a chronological build i'd rather put up pics of specific mod areas as per the list below(eg suspension) and where applicable I will comment, highlight problems or provide rational for doing things in a particular way.
CURRENT LIST:
THE CAR:
2005 Nissan 350z GT4
Kuro
No. 46/176
6 speed manual
1 previous owner
FSH
INTERIOR:
Black suede headlining conversion
Cobra Suzuka pro racing bucket seats
Buddy club side mounted seat rails
Pioneer D3 HU with integrated sat nav (full European maps & post code search) DAB radio, iPhone/iPad connectivity, Bluetooth audio streaming & phone support CD/DVD, rear camera support
Genuine Nismo floor & boot mats
OMP suede deep dish steering wheel
Works Bell Rapfix 2 removal wheel boss.
S2K starter button.
Glowshift Oil temperature gauge
Tegiwa gear stick extension
Aluminum ball gear nob
Suede gear and handbrake surrounds.
Fire extinguisher.
White LED interior bulb conversion
Nismo accelerator pedal
D1 throttle controller😈
To do/get:
Half weld in roll cage
5/6 point OMP harness
WHEELS & TYRES:
Ruff 19†lightweight wheels with Michelin Pilot Sport 2 N1 tyres 295/30/19 rears & 255/35/19 Fronts
Eibach 10mm and 20mm hubcentric spacers F&R.
Nitrogen inflation
To do/get:
Fit Orange tyre pressure and temp monitor
Rays 18" 18x9.5 wheels front and rear with 245/45/18 and 265/45/18 R888 tyres for special trackdays.
EXTERIOR:
Facelift LED tail lights
Rear wiper delete
Trico aero wipers
Bodywork by RT performance
-Nismo V2 bumper smoothed with integrated flushed carbon fibre air scoop, flushed chargespeed side skirts, flushed chargespeed rear bumper. Seibon OEM style vented bonnet with flush fit Aerocatch bonnet pins, Espirit carbon fibre GT rear wing, painted wing mirror plate
Circuitsports uprated rear boot lifters
Uprated boot popper springs
Circuitsports bonnet lifters
S2000 antenna
6k xenon bulbs
100w H7 full beam bulbs
6K LED sidelights
De-tango side and rear cluster repeaters
Clear rear cluster with LED foglight replacement bulb.
White Led number plate conversion
Z speed engine under tray.
To do/get:
Bixenon headlight conversion
Blacken headlight mod
SUSPENSION:
TEIN Monoflex 2way adjustable coilovers
TEIN EDFC
Uprated racing linear Swift springs 12kg front/10kg rear.
KW V3 3way adjustable coilovers.
Eibach front & rear adjustable Anti Roll Bars
SPL racing pro droplink F&R
SPL racing pro camber arms F&R
SPL racing pro rear traction arm
SPL racing pro rear midlink arm
SPL racing pro lockout camber and toe bolts
Superpro/ Energy suspension complete urethane bushes replacement.
- all front arms, ARBs, steering rack, all rear arms, diff, rear subframe,
Torque solution solid urethane gearbox mount
Dynosty solid engine mount
Stillen engine damper
Timrod supercharger radius rod.
To do/get:
Full race geometry setup with corner weighting
Fit solid engine mount when swapping built engine
DRIVETRAIN:
JWT heavy duty clutch
JWT Lightweight single mass flywheel
HEL braided clutch line
Motul 660 RBFfluid.
Uprated chromoly pivot
Nismo needle pilot bearing
B&W short shifter
Fluidampr harmonic balanced crank pulley
Cusco type RS LSD (set to 2way and 60% lock and 50% preload)
To do/get:
CD0009 gearbox
Carbonetic/exedy triple clutch
BRAKING:
Ksport BBK: callipers 8pot front, 6pot rears with 14" discs F&R
k sport braided lines F&R
Motul RBF 660 racing fluid
Pagid racing RS15 front & rear pads.
To do/get:
Refurb callipers in Ferrari yellow.
ENGINE:
VQ35DE REVUP
Vortech V2 T trim race(HD) supercharger with uprated FMIC
2.87 pulley
Custom braided -8 oil drain line
Stainless steel oil feed nipple
Race bypass valve filter
Professionally tuned by Mark @ Abbey motorsports 430whp /370lbft & 15psi ( limited to 5.5krpm for safety!!! Was hitting 470whp at 6.5k rpm still short of 7k revup redline 🙀!!!!)
Black satin powder coated piping
Black powdercoated 1 piece MAF tube
Radiator black coated supercharger casing
Vibrant racing black silicone hose couplers
Vibrant racing SS T- bolt clamps
CJM stage 2 fuel return system
Aeromotive 340lph fuel pump
injector dynamic 725cc injectors
Uprev MAFsensor
Uprev License
HKS 1.3bar radiator cap
HKS oil cap
HKS M40il 1 step colder iridium racing plugs
Kinetix SSV V2 racing intake - powder coated black.
Mishimoto High capacity polished radiator and fan shoud
Mishimoto low temp thermostat
Fluidampr crank pulley
AAM High capacity oil pan spacer with ports
19 row series 6 black Setrab oil cooler
Mocal thermostatic sandwich plate
Aero quip black AN10 fittings & HEL braided hoses
Mini oil catch can - removed.
Polished coolant and PAS tanks
Custom grounding kit.
To do/get:
Powder coat tanks satin black.
Supercharger CAI
Dynosty(USA) built Revup engine in progress. Rated to 700whp and 8k rev limit. Just wanting 600/7.5k rpm 👀
-Specs: CP/ wiseco forged 9.5:1 low comp pistons and eagle I beam rods, L19 fasteners, Dynosty pro gasket/seals, ACL race bearings, injected performance billet girdle, 5angle valve job. JWT C8R cams(272/272) with JWT HD springs, titanium retainers, Ferea OEM size valves, OEM HR DLC coated lifters, ferea valve stem viton seals, bronze guides, OEM crank, pathfinder, coolant bypass mod, nismo thermostat, full blueprint, balancing, clearancing and dressing for drop-in assembly.
Upgrade to CJM stage 3 twin fuel pumps
Injector dynamics 1000cc injectors
??Cosworth intake due to space issues with kinetix SSV or relocate FPR
?? Custom 8rib belt set up +/-upgrade SC head unit to V2 Ti trim
?? Syvecs or haltech pnp with race logic
?? Water/meth
EXHAUST:
DC sports SS DEI black heat wrapped headers
Motordyne ART Pipes
Invidia Gemini true dual exhaust
Torque solution urethane exhaust hangers.
To do:
?? Motordyne TDX V2
SERVICE/SCHEDULE:
Gulf competition engine oil 5w40 x2/yr or 4k miles
Redline MT 90 gearbox x1/yr (switching to Redline shockproof lightweight)
Gulf competition LS diff oil x1/yr
Motul RBF 660 brake/clutch x1/yr
Motul inugel expert coolant x1/yr
Wiper blade x1/yr
PLANS:
As per the to do/get list! 600whp here we come.
Long term bumblebee would become a garage queen track only car once I get a suitable road car to replace her for fast road duties. Safe to say its going to be a Nissan :wink:
Iromania aka Octet aka Adrian
Ifabricate aka Darren B aka Darren
Mark @ abbey Motorsport
Coz @ concept z performance USA
RT performance
Torquespeed Motorsports Worcester.
Dan @ AME
Thor racing
City motors Worcester
Many friends and traders within this forum all of whom I can't possibly list.
My family for putting up.
Edited by GT4 Zed
  • Like 3
THE CAR:
How I picked her up. Had ask the dealer to powdercoat the GT4 wheel already
Inspirations:
Mean and black GT.
Chargespeed rear
V2 bumper without horizontal bar.
V2 with double canards
Evolutions:
Genuine veliside front lip and Nismo rear wing
Nismo side skirts, carbon eyelids, lowered and spacered.
Seibon CF bulge bonnet with yellow stripe = Bumblebee
Bumblebee Wales 2013 - vortech supercharged, nismo V2 bumper with carnard.
Sneak preview of final incarnation. Just need yellow stripesðŸ‘
Edited by GT4 Zed
As all have said ~ very interesting build and well written. ;) Any engine bay shot's then & interior ones available?
I'm with Wasso on the spoiler comment but each to there own otherwise we'd all be driving around in bl**dy identical cars. :lol:
Look's great though either way. :thumbs:
Thanks guys. It was about time and I'm still going through 3k pics on photobucket to be able to put up the mod under categories if not it will just be chaotic! Should get complete by tomorrow and post up. Will also keep updating as I know I've missed loads🙀
