KyleR Posted December 30, 2013 Share Posted December 30, 2013 what year is your car and how much does it use? It's a 55, a whopping 107k on the clock, mostly motorway miles. With full servicing history. It's difficult to say, I put about 200ml very two weeks. Maybe a little more Not a 296? No, older. 280 Hmm 200ml isn't much I suppose. My car is older with only 6k less miles and burns no oil. I wonder why it does that also I'm not sure how much this will affect it or if its even noticeable but I'm sure I read buring oil reduces the octane in fuel injected? This is the first car I have had that burns oil. Doesn't leak that's for sure. I have read so many threads from people saying they all burn oil. Strange. I put 99 in it. Strange thing though, on occasions when I boot it I get a fine sweet smelling odour of oil. Not all the time. Could be the semi synthetic Iv been putting in ? It's the 296's that are infamous for burning oil, i've little to nothing about the earlier cars doing so, but I'm sure like all cars, there are a few cases about. 1 Quote Link to comment Share on other sites More sharing options...
Ekona Posted December 30, 2013 Share Posted December 30, 2013 You could run the entire engine on semi-synth if you wanted, it won't cause a single problem at all. I wouldn't do it long-term (10+ years) as it's simply not as effective as a decent fully synth, but for topping up or even over the course of a three year ownership, it won't cause a single problem at all. I wouldn't even break a sweat over it 2 Quote Link to comment Share on other sites More sharing options...
ZEUS Posted December 30, 2013 Share Posted December 30, 2013 My 53 plate DE with 104 thousand on the clock uses a bit of oil, probably only about 200ml every 5000 miles.the engine runs faultlessly and sounds sweet as a nut. I'm not worried about it in the slightest. 1 Quote Link to comment Share on other sites More sharing options...
Neilp Posted December 30, 2013 Share Posted December 30, 2013 Zeus that's nothing. You're engine sounds fine! 1 Quote Link to comment Share on other sites More sharing options...
HAMLNJ Posted December 30, 2013 Author Share Posted December 30, 2013 Cheers for the comments guys. This site is worth it's weight in gold! Servers are heavy right? It's booked for an oil change today. It's looking a little tarnished anyway and the last owner changed the oil and filter Inbetween services so might as well keep that up. Had it 6 months now and I'm going to be owning it for a long time. Quote Link to comment Share on other sites More sharing options...
R35LEE Posted December 30, 2013 Share Posted December 30, 2013 It wouldn't have caused any issues but new oil is always a good thing Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted December 30, 2013 Share Posted December 30, 2013 Should you flush your engine before a new oil change..? Quote Link to comment Share on other sites More sharing options...
Ekona Posted December 30, 2013 Share Posted December 30, 2013 Some do, some don't. In theory on a modern engine that's looked after well then it should help, by removing all the crap that sticks to everything. On the other hand some of that crap may be holding the engine together, or you could loosen off chunks that then don't drain out and float around the engine and block stuff up, and that could cause serious issues. Each to their own, I used to use it but I don't bother any more. Make of that what you will. Quote Link to comment Share on other sites More sharing options...
Ebized Posted December 30, 2013 Share Posted December 30, 2013 Only useful I would think if the engine is never worked hard to help to help clear up deposits that build up that are otherwise dissipated in engines that regularly get up to optimum temperatures. Quote Link to comment Share on other sites More sharing options...
Dblock Posted December 30, 2013 Share Posted December 30, 2013 Should you flush your engine before a new oil change..? As ekona says its a risk. Have used it before but thought it did very little. Best way to clean it out is to change oil and filter, run it for 1000miles than change oil and filter again. Quote Link to comment Share on other sites More sharing options...
