All Encompassing Wheel Size & Offset Thread
Jetpilot
Japan Racing JR 3
Front 18" 9J ET 15
Rear 18" 10J ET 25
Tyres Hankook Ventus S-1 Evo 2 K117
Front 245/40 18 97 Y
Rear 265/40 18 101Y
Not lowered
Standard camber
No spacers required
Edited by Zedrock
  • 4 months later...
Wheels jr11 hyper black
Wheel size 18 x 9.5 & 18 x 10.5
Offset ET22
Tyre size front 255/40/18 & rear 275/40/18
Lowered on tien s springs
Spacer 5mm on front to clear calipers
Edited thanks Paul. 😊
Edited by Andy_Muxlow
  • 1 month later...
Wheel Size - 19 * 9.5/10.5 Volk CE28n
Offset (front & rear) +22 all round
Tyre Size 255/35 & 285/35
Lowered Cusco Zero 2 coilovers
Arch work if necessary - Arches rolled
Rear Camber - A bit
Wheel Size - 18* 9.5/10.5 Enkei RPF1
Offset (front & rear) +15 all round
Tyre Size 245/45 & 275/45
Lowered Cusco Street Zero Coilovers
Arch work if necessary - Needs a Roll
Rear Camber - Unsure but had cusco adjustable arms fitted
Hi All,
I am considering a new set of wheels; fancy a change. Maybe some Work's...M1R :cloud9: Would somebody be able to ease my concerns or offer assistance surrounding the dreaded offsets; I believe the following specs should fit? :wacko:
Front
19 x 9.5J +ET20 with a 245 tyre
Rear
19x 10.5J +ET20 with a 275 tyre.
I am after an aggressive yet realistic set up. The Zed has had a number of suspension upgrades and I am not averse to minor arch modifications. What I must bear in mind is that I have an Akebono set up and I want to avoid spacers.
Any help woud be greatly apprecited. My build thread can be found here should it help;
http://www.350z-uk.com/topic/83318-ceejays-jdm-and-bay-let-the-fun-begin/page__st__140
Hi All,
Front
Rear
Are you looking for a flush or stretched look?
I was kind of hoping this thread would be for examples and info so members could work out what works and what doesnt and give them the confidence to get it right, not fitment queries.
Could we try to keep it as intended please guys :)
Its also a bit of a shame that 2 pages is as good as it gets with all of the members running nice rims :(
Edited by Jetpilot
Thanks Steveo; +8 sounds aggressive? I presume worse case scenario at +15 I could inlude a 5mm spacer to achieve +10? ideally want to get it bang on.
Also, do people vary front and rear offsets or opt for the same all round?
There customs made wheels don't run spacers just get them in right offset
To try and get the post back on track.
OEM 370 Wheels:
Fronts: 19x9 +47
Rears: 19x10 +30
Tyres: Bridgestone Potenza RE050A (Currently OEM)
F: P245/40R19
R: P275/35R19
Lowerd -30mm on Eibach Pro Springs
Standard camber
20mm Spacer on Front to clear Brembo's
no Arch work required
NOTE: You MUST have the orginal OEM 370 Wheel nuts - No others will do
Japan Racing JR18
Wheel Size 19x 11 & 19 x 9.5
Offset (front & rear) rear 22 front 20
Tyre Size 275/35 rear & 235/35 fronts
Lowered Eibach Pro Springs
Spacer sized if used na
Arch work if necessary Rolled rears
Rear Camber -1
Niche Targa M129 - Anthracite
Wheel Size:
19 x 8.5 Fronts
19 x 10 Rears
Offset (front & rear):
+25 Front
+25 Rear
Tyre Size:
Michelin Pilot Super Sports 245/35/19 Fronts
Michelin Pilot Super Sports 275/35/19 Rears
Lowered:
Stock Height
Spacer sized if used:
No Spacers Required
Arch work if necessary:
None Required
Rear Camber:
Stock
  • Like 3
  • 3 weeks later...
  • 3 weeks later...
For anyone really struggling to find you right size wheels to buy this link might be handy.
http://www.willtheyfit.com/index.php?width=235&aspect=50&diameter=17&wheelwidth=7.5&offset=30&width2=275&aspect2=40&wheel_size=18&wheel_width=10-5&offset2=15
You basically type in your existing tyre size and wheels size details and your new wheel and tyre size details and it shows you stuff like arch gap loss, how much more poke you will have, even how much your speedo will be effected!
I've attached a picture of a standard 350z wheel and tyre size with what people normally tend to run after market. :)
  • 2 months later...
