How wide
teamshock nick
I was running 9.5J ET2 on the front and around ET - 3 on the rear. I was quite low though and had to get my rear arches rolled
Ideally if I was doing it again I would go much more aggressive! add another 20mm each side :)
Edited by BillyZed
I run 9.5j ET20 all round with a 5mm spacers on the front and 25mm at the rear. Mines lowered slightly but there is still room to go wider without rolling my arches.
hope that helps a little.
No rolling on the rears with -5, is that with a fair bit of camber and stretch on the tyre?
Edited by Jetpilot
I dont have -5 on the rears or have you quoted the wrong one? As for tyres I run 225/45/18 (front, stretched) 245/45/18 (rear, little stretched)
Edited by Jared350z
If your et 20 all round and running 25mm spacers on the rear your effectively -5. or have i read that wrong?
I dunno as it took me ages to work out the whole ET lark, either way I havent rolled my arches (yet) but My tyres are streched abit at the back but theres still room.
Although the offset is 20, you have pushed them out a further 25mm by adding the spacers, so effectively making them -5 :)
