Beavis Posted June 26, 2007 Share Posted June 26, 2007 If you are a GT4 owner or an MY06 owner are you using oil? Basically if you have the 300 ps engine or commonly known in America the rev-up engine are you reguarly topping up with oil? I am doing this to compare this with experiences of this engine in America. There is talk of a possible TSB to fix this problem. Possibly an ecu update, though this might be just pie in the sky. Quote Link to comment Share on other sites More sharing options...
Beavis Posted June 26, 2007 Author Share Posted June 26, 2007 Lots more info here http://www.my350z.com/forum/showthread.php?t=232332 Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted June 26, 2007 Share Posted June 26, 2007 Vote cast. Mine uses approx 0.5ltr every 1k miles and has done so from day one. Quote Link to comment Share on other sites More sharing options...
MarkW Posted June 26, 2007 Share Posted June 26, 2007 Voted yes a little. Used 2-3 litres in 10k miles I think. Thanks for the reminder - havent checked it since service 4-5 weeks ago Quote Link to comment Share on other sites More sharing options...
Beavis Posted June 26, 2007 Author Share Posted June 26, 2007 Who else voted? if you do vote could you please had a post with your experience. Quote Link to comment Share on other sites More sharing options...
Stew Posted June 26, 2007 Share Posted June 26, 2007 edited because I'm a dumbass Quote Link to comment Share on other sites More sharing options...
mugwump Posted June 26, 2007 Share Posted June 26, 2007 was concerned about mine so had the dealer perform a consumption test, was told it was within normal limits. Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted June 26, 2007 Share Posted June 26, 2007 was concerned about mine so had the dealer perform a consumption test, was told it was within normal limits. How much does it use then? Quote Link to comment Share on other sites More sharing options...
Beavis Posted June 26, 2007 Author Share Posted June 26, 2007 was concerned about mine so had the dealer perform a consumption test, was told it was within normal limits. How much does it use then? Yep how much did it use? Come on others please who this applies too. Quote Link to comment Share on other sites More sharing options...
mugwump Posted June 26, 2007 Share Posted June 26, 2007 dont ask me to swear on the numbers, but from what I can recall the dealer process was; - drain the oil - flush the engine with errr..... .... "engine flush" or toilet duck???? - top the oil up to the "max" mark - the car was then returned to me to drive 600 miles, why 600? Ask nissan.... they told me to check the oil frequently and return immediately if it got to the min mark but under no circumstances to add any before I returned. - 600 miles later..... I return to the dealer - The dealer then checked the consumption by topping back up to the "max" mark. My consumption was ~200-250cc, I seem to recall the limit was about double that ie; half a litre in 600 miles (but dont quote me on that!!) Since then my consumption has remained at about this level, no more, no less but I still monitor it closely. Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted June 26, 2007 Share Posted June 26, 2007 dont ask me to swear on the numbers, but from what I can recall the dealer process was; - drain the oil - flush the engine with errr..... .... "engine flush" or toilet duck???? - top the oil up to the "max" mark - the car was then returned to me to drive 600 miles, why 600? Ask nissan.... they told me to check the oil frequently and return immediately if it got to the min mark but under no circumstances to add any before I returned. - 600 miles later..... I return to the dealer - The dealer then checked the consumption by topping back up to the "max" mark. My consumption was ~200-250cc, I seem to recall the limit was about double that ie; half a litre in 600 miles (but dont quote me on that!!) Since then my consumption has remained at about this level, no more, no less but I still monitor it closely. Much the same consumption as mine then. TBH I have also heard that 1ltr per 1K is the maximum permitted and this is the reason I have not yet pressed the issue it with the dealer. Quote Link to comment Share on other sites More sharing options...
Kev946 Posted June 26, 2007 Share Posted June 26, 2007 I voted frorm when I had mine. I never had to top mine up and never really noticed any consumption. Quote Link to comment Share on other sites More sharing options...
Sarnie Posted June 26, 2007 Share Posted June 26, 2007 I voted 'No' as mine is fine Quote Link to comment Share on other sites More sharing options...
Beavis Posted June 27, 2007 Author Share Posted June 27, 2007 So up to press it does not look too bad on the oil consumption. Mine needed topping up a couple of times up to about the 8000 mile point but seems to have slowed down alot, may have been an issue with running in? Any how keep the votes coming. Quote Link to comment Share on other sites More sharing options...
MAB Posted June 27, 2007 Share Posted June 27, 2007 I must be a numpty but I find it very hard to check my oil. I wait till the engine is warm. Pull the dipstick - and wipe, then replace (with great difficulty I have to admit - its like a bloody corkscrew !) Then I pull the dipstick again and can see no clear oli level, it seems all over the stick. What on earth am I doing wrong? Quote Link to comment Share on other sites More sharing options...
Beavis Posted June 27, 2007 Author Share Posted June 27, 2007 I must be a numpty but I find it very hard to check my oil.I wait till the engine is warm. Pull the dipstick - and wipe, then replace (with great difficulty I have to admit - its like a bloody corkscrew !) Then I pull the dipstick again and can see no clear oli level, it seems all over the stick. What on earth am I doing wrong? Well firstly it is best to check the engine oil when cold. Obviously on a flat level surface. Granted its a bit fiddly getting dipstick back into the hole but you should be able to see the oil level clearly. Other than that i cant see what you are doing wrong. Quote Link to comment Share on other sites More sharing options...
MAB Posted June 27, 2007 Share Posted June 27, 2007 I must be a numpty but I find it very hard to check my oil.I wait till the engine is warm. Pull the dipstick - and wipe, then replace (with great difficulty I have to admit - its like a bloody corkscrew !) Then I pull the dipstick again and can see no clear oli level, it seems all over the stick. What on earth am I doing wrong? Well firstly it is best to check the engine oil when cold. Obviously on a flat level surface. Granted its a bit fiddly getting dipstick back into the hole but you should be able to see the oil level clearly. Other than that i cant see what you are doing wrong. really - when cold? Yes I am checking on a flat surface -a garage forecourt. So it has to be when cold then ? Quote Link to comment Share on other sites More sharing options...
ByteJuggler Posted June 27, 2007 Share Posted June 27, 2007 So it has to be when cold then ? If the engine's hot/been run recently then the oil would've been knocked up into the engine and so the dipstick will give an inaccurate (lower than real) reading. Leaving it to cool off lets the oil run down and settle in the bottom of the engine making an accurate reading possible. Quote Link to comment Share on other sites More sharing options...
Beavis Posted June 28, 2007 Author Share Posted June 28, 2007 More voters please, we must have more than 7 that have the 300ps engine Quote Link to comment Share on other sites More sharing options...
MAB Posted June 28, 2007 Share Posted June 28, 2007 just to get the z on flat ground and the engine cold - not easy as my drive is a tad steep. As soon as I have I will. Quote Link to comment Share on other sites More sharing options...
holtehero Posted June 28, 2007 Share Posted June 28, 2007 i've had mine two weeks, so haven't really monitored it. Its in for its P2 service today so i will check the level tonight and then over the next few weeks and report back Quote Link to comment Share on other sites More sharing options...
WoREoD Posted June 28, 2007 Share Posted June 28, 2007 Voted No. Dealer gives me a litre bottle to top up between services which I tend to put in at about 5000 miles when its "gorn dawn a bit". And it does get revved to 7k - regularly!! JK Quote Link to comment Share on other sites More sharing options...
Beavis Posted June 28, 2007 Author Share Posted June 28, 2007 Thanks guys, just trying to see how we compare to the states, but strange the autocar zeds engine had to be changed.!! Quote Link to comment Share on other sites More sharing options...
WoREoD Posted June 28, 2007 Share Posted June 28, 2007 The GT4s were a limited engine production run prior to the MY06 model. Haven't heard of a GT4 with oil consumption probs which leads me to think whatever the problem is it only became such when they were doing "normal" production. Quote Link to comment Share on other sites More sharing options...
ByteJuggler Posted June 28, 2007 Share Posted June 28, 2007 I must be a numpty but I find it very hard to check my oil.I wait till the engine is warm. Pull the dipstick - and wipe, then replace (with great difficulty I have to admit - its like a bloody corkscrew !) Then I pull the dipstick again and can see no clear oli level, it seems all over the stick. What on earth am I doing wrong? If the engine's recently run/warm then the oil would've been knocked up in the engine, including the dipstick hole/tunnel, which means you'll get an oil smeared dipstick most of the time, and if if you do manage to get a reading form it, it'll probably be lower than actual oil level. So, let the oil settle/run down into the engine (let it cool down) and you'll get a more accurate reading more easily. Quote Link to comment Share on other sites More sharing options...
