stuey Posted June 26, 2007 Share Posted June 26, 2007 duz anybody know how to remove the exterior trim which goes from the windscreen pillar to above the door window Quote Link to comment Share on other sites More sharing options...
M13KYF Posted June 26, 2007 Share Posted June 26, 2007 that should do ya Quote Link to comment Share on other sites More sharing options...
andywrx Posted June 26, 2007 Share Posted June 26, 2007 I've not removed t myself but watched the RAC Windscreen's remove mine. It's either bothed or screwed, under the window seal, undo these and it is then hooked in under the top of wing. Be careful not to scratch the wing (they did mine!) as you take it off as the end is sharp. Quote Link to comment Share on other sites More sharing options...
stuey Posted June 26, 2007 Author Share Posted June 26, 2007 do both of these trims have to be removed to replace the screen.? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted June 26, 2007 Share Posted June 26, 2007 yes Quote Link to comment Share on other sites More sharing options...
stuey Posted June 26, 2007 Author Share Posted June 26, 2007 cool.. i will watch them do it tomoro........ i think my screen has come unbonded in the top corner coz water has been comming inside the car behind the weatherstrip and dripping down on to the door trim........ so hopefully this will sort it............. unless anyone knows differant or had the same problem..?? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted June 26, 2007 Share Posted June 26, 2007 here ya go Quote Link to comment Share on other sites More sharing options...
stuey Posted June 26, 2007 Author Share Posted June 26, 2007 thanks mike very helpful............ anyone else had water entering in the same place...........?? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted June 26, 2007 Share Posted June 26, 2007 print them out and take them with you incase they get stuck Quote Link to comment Share on other sites More sharing options...
stuey Posted June 26, 2007 Author Share Posted June 26, 2007 print them out and take them with you incase they get stuck good thinking batman...........!! Quote Link to comment Share on other sites More sharing options...
M13KYF Posted June 26, 2007 Share Posted June 26, 2007 Mr Incredible please Quote Link to comment Share on other sites More sharing options...
