flirt Posted June 26, 2007 Share Posted June 26, 2007 prob a piece of ****, anyone done it or got a guide made up! t Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted June 26, 2007 Share Posted June 26, 2007 It is a piece of cake. The fitting instructions that come with them are quite good as well. Essentially, you can fit the fronts by puting the steering on full lock, but you will need to remove the rear wheels for the back ones. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted June 26, 2007 Share Posted June 26, 2007 someone did write a little guide if you do a search Quote Link to comment Share on other sites More sharing options...
rickya Posted June 26, 2007 Share Posted June 26, 2007 Rear ones can be fitted without removing wheels by using a right angle drill/scredriver adapter. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted June 26, 2007 Share Posted June 26, 2007 guide now in the guides section http://www.350z-uk.com/forum/viewtopic.php?t=6151 Quote Link to comment Share on other sites More sharing options...
rmmackfc Posted June 26, 2007 Share Posted June 26, 2007 Easy, I did rears with help from someone. He held them, so I could check they were square etc... then drill away. Fronts are easy. Quote Link to comment Share on other sites More sharing options...
jim Posted June 26, 2007 Share Posted June 26, 2007 Easy, I did rears with help from someone. He held them, so I could check they were square etc... then drill away. Fronts are easy. +1 Quote Link to comment Share on other sites More sharing options...
flirt Posted June 26, 2007 Author Share Posted June 26, 2007 so i take it you remove the existing pins in the car and put them through the holes of the parts then screw down??? Quote Link to comment Share on other sites More sharing options...
rmmackfc Posted June 26, 2007 Share Posted June 26, 2007 On the front, yip Rears are drilled Quote Link to comment Share on other sites More sharing options...
